03-12-2008, 05:46 PM
#1
Sirius USB Adapter
Hope this is the correct forum for this question ...
I'm looking at MJS's SC-C1 USB Interface for Sirius ... but I have a question ...
Where does the unit get power from? I see there's an input for a power supply ... but the "What's Included" doesn't list an external power lead ...
Anyone use this device before? What should I use for power? Does it power off of USB?
perk03z06
Windows XP PC
InTruckPC
P4 3.0 GHz Hyperthread CPU, 1Gb RAM, 120 Gb Hard Drive, DVD/CD-RW, Centrafuse XLE 1.47, 7" Xenarc, GPS, EV-DO via Samsung i730 ... more coming!
03-13-2008, 03:21 PM
#2
it's 12 volts, so it's not powered from USB, which is 5v. It can be powered from your computer supply's 12v line, or car 12v power. I don't recognize the connector though. Ask MJS or on their forum about that.
03-13-2008, 04:14 PM
#3
Fusion Brain Creator
its a regular 2.1mm power jack. It needs regulated 12v power, so from the PSU is the only option. If you power it from your car it will go kaboom.
When I bought mine from mp3car a year and a bit ago, it came with a power jack that you need to solder.
All the instructions are in the manual.
#4
Mitch emailed me ... there's a terminator in that connector when they ship, so I can terminate raw wireand everything will work.
Thanks!
perk03z06
Windows XP PC
InTruckPC
03-13-2008, 07:34 PM
#5
Raw Wave
Is this the same with the serial cable? Can I connect it to the car directly? I heard that the XM DIRECT can accept unregulated power.
PLANNING [ 100%]
CAR PC ITEMS [ 100%]
INSTALL OF PC [ 100%]
BUG WORKOUT [ 75%]
INTERIOR MODS [ 50%]
BUDGET [ 380%]
HiJackZX1 Work Log
03-14-2008, 12:49 AM
#6
No the XMD can accept un-regulated 12V power.
03-14-2008, 09:06 AM
#7
Raw Wave
thats what I said it CAN accept unregulated power.
PLANNING [ 100%]
BUG WORKOUT [ 75%]
BUDGET [ 380%]
HiJackZX1 Work Log
03-22-2008, 05:56 PM
#8
Haven't seen the SCC1 in with a serial interface ... I think it's just USB.
perk03z06
Windows XP PC
InTruckPC
03-22-2008, 06:16 PM
#9
I have the SC-C1 usb adaptor for my SC-H1 receiver and works great.
My carpc worklog
03-22-2008, 06:54 PM
#10
Awesome. That's great to hear. I never used one before ... cool it has no problems.
perk03z06
Windows XP PC
InTruckPC
03-23-2008, 12:02 AM
#11
the sc-c1 uses 12v unregulated... all regulation is done inside the SC-C1 Tuner!!!
using a SC-C1 on a SC-H1 IS NOT RECOMENED
and if powered via THE SC-C1 Interface, damage may occour
ie dont mix the home with the car
(there is a way to do it... but unless u need optical, dont bother with sc-h1)
mitch
-Thanks
Mitch
www.rush2112.net
Spread before you is your soul
So forever hold the dreams
within our hearts
Through nature's inflexible grace
I'm learning to live
03-23-2008, 03:29 AM
#12
Yup, the SC-H1 requires 5V. I have a Audigy 2 NX sound card with 1 optical input so I took advantage of the SC-H1's optical out, which is why I went that route. Audio sounds really crisp with it.
My carpc worklog
03-23-2008, 04:00 AM
#13
mitch
really? wow. Well now I can power it off the regular car line instead of a wire hanging outside the PC case to it!
| Thread Tools |
| Display Modes |
Linear Mode
