The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General MP3Car Discussion
Thread Tools Display Modes
Old 03-30-2008, 11:26 PM   #1
blackcobra487's CarPC Specs
Vehicle: 03 Accord
My Photos: (0)
USB hub help
I just bought a powered USB hub from a local computer store. The only issue is that the data cable slits into two plugs and the second one is where it draws power. I split open the second cable to find that there are more than two wires, since the manual said it was for power only I only expected two. My question is, with the second USB plug, is it safe to assume the red wire is positive power while the black is negative and the other two would be for data?
The hub does have a spot for a barrel connector, but there's no way to tell what's + or - so making a wire seems out. Unless somebody is pretty sure which one would be which. Any help guys?
blackcobra487 is offline   Reply With Quote
Sponsored Links
Old 03-30-2008, 11:31 PM   #2
Fusion Brain Creator
2k1Toaster's CarPC Specs
2k1Toaster's Avatar
Vehicle: 2001 Honda Civic EX Coupe
My Photos: (1)
the whole reason for a powered hub is to not draw power from the USB bus. With 2 USB plugs it pretty much defeats the purpose. You need to use the barrel connector. It should have an ac adapter. Look at the adapter and it should say 12v @ 1.5A or something as well as a picture of a solid circle with a circle around it, and one of them will be labeled as + or -. The solid circle is the middle of the barrel and the outer circle is the barrel outside.
Old 03-31-2008, 08:39 AM   #3
Vehicle: 03 Accord
My Photos: (0)
That's exactly what I would want to do, but I bought this thing for cheap at a second hand computer store and it didn't have the ac adapter. I feel like I'm going to have to chance it.
Old 03-31-2008, 12:06 PM   #4
2k1Toaster's Avatar
My Photos: (1)
There is no chance it here. It is pure math.
If you want to power say 4 ports at 500mA each, then you need 2A. Now each USB port can supply 500mA max, 100mA at startup. So if you plugged in your 2 ports, you will get 1A which means everyport is underpowered for bus powered devices.
As they say "the cheap comes out expensive". Go buy a real hub with a brick you can hack up for $20 new.
Old 03-31-2008, 05:59 PM   #5
nolimitssaila's CarPC Specs
Vehicle: 1987 Chevrolet Monte Carlo
My Photos: (0)
or if it's that cheap, just go ahead and hack up that hub. what's the harm in messing it up?
nolimitssaila is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Opus 320 and 2 StarTech.com 7 Port USB 2.0 Hub HiJackZX1 General Hardware Discussion 4 01-07-2008 03:42 PM
Powered Hub, Lots of USB Devices! Will this work? adamharrisuk General Hardware Discussion 4 05-14-2006 11:00 PM
My USB/Wifi troubles. JPuma General Hardware Discussion 0 09-23-2005 11:44 AM
USB Hub does not show HD after cold boot d_sellers1 General Hardware Discussion 9 04-05-2005 01:46 PM
USB HUB problems???? chuckctv Input Devices 7 10-08-2004 11:38 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
