Heck I've been using an inverter (which only adds more parts to fail) and I've had great luck. I changed out the inverter once because the first one's cooling fan died. Other than that, no failures.
I did just ordered an M2-ATX yesterday because my new amps are drawing too much power and my battery needs to be replaced. When listening at very high volumes, my inverter will sometimes go into protect mode, shutting down my PC in the process. Not a major issue as the M2 and a new battery will fix this. It's also not an issue caused by the PC in any way. I never had this problem until I upgraded my sub amp to bit more power so I know that's the cause.
CarPC:
1.8GHz Northwood, Intel 845 Mobo, 512MB DDR, 1x20GB + 1x160GB, Intel GPU, SB Live 5.1
Sound System:
Phoenix Gold RSD 65cs 6.5" Comps, 2 x 12" Pioneer 305DVC, Visonik V500HC
