Go Back   MP3Car.com > Mp3Car Technical > General MP3Car Discussion
Old 04-22-2008, 10:54 PM   #1
Cheekz185 will become famous soon enough
VoomPC-2 and Via SN-18000G
Does anyone know if the VoomPC-2 is compatible with the VIA Sn-18000G? I am thinking about buying the 2. Any infor would be greatly appreciated.
-Thanks!
2002 Mitsubishi Galant
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
Cheekz185 is offline   Reply With Quote
Old 04-25-2008, 09:15 AM   #2
BlackStealth is on a distinguished road
That VIA SN 18000G CPU cooler is huge. My Intel D201GLY2A barely fits inside the voompc-2 case, so if it's any taller than that then definitely not.
I don't really see the advantage to using this motherboard over the $75 Intel board. It may offer PCI express graphics slot, but that won't do you any good if you use the voompc-2 case. Intel board is faster, fits, and costs much less.
BlackStealth is offline   Reply With Quote
Old 04-25-2008, 02:39 PM   #3
as per the manual it says that it is only 34.7mm high its just a bit higher than the ram
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
Old 04-25-2008, 05:24 PM   #4
Looks like you'll have no problem clearing as the intel board's CPU heatsink/fan is 45mm tall.
http://www.minipc.de/catalog/il/881
Old 05-02-2008, 12:15 AM   #5
blackcobra487 is an unknown quantity at this point
Go with a case from www.mo-co-so.com. Although slightly taller than a voom, it's very rigid and my Intel D201GLY2A fits with plenty of room. The cases are also very close in price.
blackcobra487 is offline   Reply With Quote
