The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General MP3Car Discussion
Thread Tools Display Modes
Old 04-24-2008, 07:12 AM   #1
nasa's CarPC Specs
Vehicle: 2003 Honda Accord Sports Coupe
My Photos: (8)
Ideas for mounting CarPC in trunk
Hi,
I would like to clean up my Accord trunk... Specifically, I am looking for ideas on mounting my CarPC in there. I have tried for ideas, but so far I am coming up dry. Could I get some suggestions? (Pictures would be great)....
My car is an Accord, but suggestion from any trunk install could lead to more creative thoughts flowing....
Nasa
nasa is offline   Reply With Quote
Sponsored Links
Old 04-24-2008, 09:22 AM   #2
nobb's CarPC Specs
My Photos: (14)
Ive found that mounting the pc by screwing it to the back of the rear seats works well. Looks neat, and I can diagnose any problems from within the car (rather than having to pop the trunk) because my rear seats can flip down. Thats only if you have a fairly compact case though.
nobb is offline   Reply With Quote
Old 04-25-2008, 06:14 AM   #3
greatwhite's CarPC Specs
greatwhite's Avatar
Vehicle: 2004 Chrysler 300M Special
My Photos: (1)
Hatch or sedan?
Here's what I did in my 300:
Hinged shelf.
If you've got a hatchback, you can mount in on the sides, under panels, seatbacks (as mentioned) etc.
You're really only limited by your imagination..................
Cheers
Leonardo Da Vinci
greatwhite is offline   Reply With Quote
Old 04-25-2008, 06:24 AM   #4
nasa's CarPC Specs
My Photos: (8)
GreatWhite,
Sedan.
BTW:
"You're really only limited by your imagination.................."
Given my imagination is on short supply, I have to borrow ideas from everyone else!!!
Old 04-27-2008, 09:22 PM   #5
FusionFanatic's CarPC Specs
FusionFanatic's Avatar
Vehicle: '07 Ford Fusion
My Photos: (56)
where is your current carPC mounted/installed?
in my previous system/installation I had my laptop/docking station mounted to an MDF shelf that sat on the floor of the trunk (amplifier on the bottom 'shelf' with the laptop on the top 'shelf' above it).
later on, to save space I hung a metal shelf from the rear deck (it wasn't actually a shelf, it was a steel cover from an old horizontal desktop PC case) from the rear deck. this saved alot of space but unfortunately it got so hot up there (when the car was sitting in the hot sun) that my laptop would overheat and shutdown. I left the 'shelf' there and now I use it as a general storage shelf
neither solution was ideal, and I never really wanted it in the trunk but at the time money was tight so I didn't want to spend any money on a new system so I used what I already had. the laptop/DS was too big to fit anywhere else, so it had to go in the trunk.
I just replaced my old laptop with a Intel mini-ITX system in a small aluminum case from Mo-Co-So. this case allows the motherboard tray to be installed normally or upside down in the case, which gives you a few different mounting options (including hanging it from the rear deck or mounting it to the side or seat-back).
this was much smaller than the laptop/DS and could easily fit under the passenger seat. so that's where I installed it. now I don't have to deal with the heat issues in the trunk or the cable extensions / long wires. do you have any other mounting locations you are considering or are you only considering the trunk? (and if so, why?)
FusionFanatic is offline   Reply With Quote
Old 04-28-2008, 07:04 AM   #6
nasa's CarPC Specs
My Photos: (8)
FusionFanatic,
My carputer is located in my trunk. It's mounted on a mdf board (with 2 rails, so I can remove the computer as necessary) which is screwed into the driver side wall of the trunk (there's a metal piece between the outside shell of the car and the fabric inside). I am using an Opus solutions case, which is to big to fit anywhere on the inside of the car. Even if I was using a smaller case -- I have an amp under the passenger seat, my DSP processor under the driver seat, DVD drive/usb hub/DSP control unit in my center console, USB UIRT/Car2PC behind monitor in the area that use to be the little cubby area, and the glovebox is actually used to carry stuff (ie: proof of insurance, tissue (for allegies), etc).
I haven't had any issues concerning heat with the carputer in the trunk.
Basically, I would like it to not look so *getto*.....
Once I get my camera back, I will post some pictures and get some feedback on it.
Nasa
Old 04-28-2008, 01:53 PM   #7
HiJackZX1's CarPC Specs
HiJackZX1's Avatar
Vehicle: 03 Dodge Durango SLT
My Photos: (231)
One thing you have to do is make sure the HDD is on it side, so when you hit bumps the arm can move along the disk surface. If you have the HDD flat then the needle can slam down directly onto the disk, damaging the arm, disk or both.
PLANNING [50%]
CAR PC ITEMS [75%]
INSTALL OF PC [80%]
INTERIOR MODS [35%]
BUDGET [380%]
HiJackZX1 Work Log
HiJackZX1 is offline   Reply With Quote
Old 04-29-2008, 06:46 AM   #8
nasa's CarPC Specs
My Photos: (8)
Hi guys,
To see what I presently am doing, please look at my worklog....
http://www.mp3car.com/vbulletin/work...e-worklog.html
Old 05-05-2008, 02:25 PM   #9
wi77iam's Avatar
Vehicle: 2004 Subaru WRX STi
My Photos: (0)
I attached my PC and amp to a piece of mdf like in Greatwhite's first pic. But it is on the opposite side of the board from his, and it hinges from the trunk floor. So when open it sits on the floor and when closed, you just see the back of the mdf covered with some trunk carpet. All nice and hidden. I put a 120mm fan in the middle to help cooling. I can't find my pics so I hope you understand what I'm saying.
wi77iam is offline   Reply With Quote
Old 05-05-2008, 11:28 PM   #10
My Photos: (56)
does you setup still look like this?
if so, I don't think that looks "ghetto" at all. I think it looks about as good as any trunk install could look. it's mounted vertically and it's compact. the only thing I would suggest is that you neaten up your wires/cables
Sponsored Links
Old 05-06-2008, 05:25 AM   #11
nasa's CarPC Specs
My Photos: (8)
Yeah that's my setup,
and thanks for the FusionFanatic. I'll work on those cables....
Nasa
Old 05-08-2008, 11:57 AM   #12
lukec's CarPC Specs
My Photos: (0)
How pretty do you want to make it? You could get really "pro" on it and fab up a nice shelf. Maybe something that will allow you to add an amp and a capacitor if you plan on throwing a system in there.
I've been looking around on cardomain.com to get some fabbing ideas for the same purpose for my bravada and there's a lot of boxes that people have built that might give you some inspiration. Search fiberglass on cardomain.com if you want to see what other people are doing.
For myself, I'm planning on doing a nice 3 stack shelf that will have a recessed shelf for me to rest my pc in, then a shelf for an amp, and a shelf for an inverter. I was thinking maybe I could put a ledge, like a riser at the top or bottom of each of the shelves to put a neon in to really kind of show off each component.
I've already bought all of my supplies to fab a shelf, total it was under $80 for the fiberglassing materials. So far at least.
lukec is offline   Reply With Quote
Old 05-08-2008, 12:17 PM   #13
crooper's CarPC Specs
crooper's Avatar
My Photos: (0)
Here's my PC mounting solution. My case fits nicely into the dip in the plastic molding (I don't have any pics of it though, go figure). I couldn't do a rear seat mount because of my subs.
crooper is offline   Reply With Quote
Old 05-09-2008, 12:42 AM   #14
elBradford's Avatar
Vehicle: 2001 Ford ZX2
My Photos: (1)
I've gotta go to bed... everytime I see the word "trunk" I read "truck".
monkey stole my pen
My Worklog
elBradford is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Ideas on hardening trunk lid from exterior prying or lock cylinder pulling jbeletti General Hardware Discussion 4 01-02-2007 08:03 AM
CarPC / InDash LCD / HU install in 1999 Toyota Avalon jbeletti Show off your project 4 12-31-2006 09:14 AM
CarPC Brainstorming Ideas Bugbyte General MP3Car Discussion 0 12-27-2004 02:40 PM
a warning to all prospective carputer installers! dazza666 General MP3Car Discussion 33 08-01-2001 12:15 PM
some accessory ideas moossmp3 General Hardware Discussion 2 09-08-2000 05:27 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
