The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General MP3Car Discussion
Thread Tools Display Modes
Old 05-03-2008, 06:17 PM   #1
My Photos: (0)
New PC Setup, Nothing happens when Key Turned
Hi guys,
Just wired up my second car pc today and nothing happens when i turn the key.
I have a jetway motherbaord on an M2 ATX.
Since the motherboard has been working in house then im thinking the problem is with the M2 which i bought (used) either from here or ebay some time ago but have not been able to test.
I have checked the power to my dist block and the cables goin to the m2 atx all have 11.7 volts, which i assume is ok as its close to 12.
I have tried every combination of wire seating on the M2 power switch to motherboard power switch cable in terms of polarity.
Oh yeah i also tried to see if a molex live pin had any power and it had 0.3 something.
Is there any other places i can check to see if the power is making it, or any other suggestions at all?
grandimperial is offline   Reply With Quote
Sponsored Links
Old 05-03-2008, 06:25 PM   #2
Fusion Brain Creator
2k1Toaster's CarPC Specs
2k1Toaster's Avatar
Vehicle: 2001 Honda Civic EX Coupe
My Photos: (1)
if you connect the switched line of the m2 to constant power, does itwork?
Also if your M2 is too old, you may need to solder a replacement cap there. Known issue with jetway boards and the M2
Old 05-03-2008, 06:47 PM   #3
My Photos: (0)
Thanks for your fast reply.
I will connect a constant power to switched line tomorrow.
I dont think i will be able to solder a cap onto the board since my soldering skills are very poor.
Is there any way i can tell the age of my m2
Old 05-10-2008, 06:20 AM   #4
My Photos: (0)
SORTED - Prob was with old version of MATX not sending enough pulse to the mobo to power it on.
Swapped it with the M2 ATX in ym other car and it works!
Thanks everyone.
Sponsored Links
vB code is On
Trackbacks are Off
2000 Mitsubishi Verada Car PC Install MitchellO Show off your project 16 06-05-2008 07:05 AM
How2 control CarPC from key fob.... NotchbackVW Power Supplies 1 09-21-2007 05:27 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
