The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General MP3Car Discussion
Thread Tools Display Modes
Old 05-12-2008, 09:04 AM   #1
My Photos: (0)
PC Won't Boot Intermittently.
Hi guys,
Im experiencing a problem on a new install where sometimes when you turn the key to turn the PC on, the motherbaord fan comes on and so does the screen but the screen shows "no signal" but never finds a signal.
The system is:
M2 ATX
Lex/Jetway BNO86T
Lilliput screen powered via molex.
2.5" HDD
Basically the system boots properly 2/3 times but then the remaining 1/3 the above happens.
The only way to get round it is to keep disconnecting power and trying to turn on again and eventually it starts properly or one time i removed CMOS battery and it worked but might be coincidental.
I have tried lugging my huge CRT monitor outside and plugging it in when the problem occurs and this also receives no signal.
This leaves me to beleive it is the mobo or possibly PSU but the M2 came direct form a working machine.
I have also tried turning it on without the HDD attached and still no difference.
Anyone know of any issues that may cause this?????
I think i may try and find a EPIA board instead because i already have one of those in my other car which works flawlessley.
Thanks guys.
grandimperial is offline   Reply With Quote
Sponsored Links
Old 05-12-2008, 09:23 AM   #2
GiODi's CarPC Specs
Vehicle: 2001 Infiniti QX4
My Photos: (1)
This may be helpful... honestly, I did it read the thread because it doesn't pertain to me at all, but it could give you some helpful search tips if not the answer.
http://www.mp3car.com/vbulletin/powe...tx-jetway.html
GiODi is offline   Reply With Quote
Old 05-12-2008, 09:37 AM   #3
My Photos: (0)
I think this looks like it could be the problem.
Unfortunatley i bought my mobo 2nd hand so i dont know where i stand in terms of a replacement/fix.
Old 05-12-2008, 09:52 AM   #4
TimmyM's Avatar
My Photos: (22)
I just ran into this same problem with a M2ATX and D201GLY. I unplugged the M2ATX to move it then plugged it back it and it never worked again. I bought a new M2ATX and now I have this problem.
Goes in and out of hibernation then all of a sudden, nothing. I've even taken it into the house and used a standard PSU and still had the problem. I think when the M2 went it might have damaged the MB.
TimmyM is offline   Reply With Quote
Old 05-13-2008, 06:23 AM   #5
HiJackZX1's CarPC Specs
HiJackZX1's Avatar
Vehicle: 03 Dodge Durango SLT
My Photos: (231)
I had the same issue towards the end of my first install..... I figured it was the MoBo, but found it was the M2-ATX. On install number 2, the M2-ATX was too under powered so I had to upgrade to a OPUS 320 anyways.
PLANNING [50%]
CAR PC ITEMS [75%]
INSTALL OF PC [80%]
INTERIOR MODS [35%]
BUDGET [380%]
HiJackZX1 Work Log
HiJackZX1 is offline   Reply With Quote
Old 05-13-2008, 09:21 AM   #6
TimmyM's Avatar
My Photos: (22)
I've had that same thought but I've had the same setup M2ATX/D201GLY for over a year and didn't have any problems. I did add a powered USB hub but even with that disconnected I still have the same problem. I've ordered a replacement motherboard so we'll see in a couple of days.
Sponsored Links
vB code is On
Trackbacks are Off
Pc in the boot how do i turn it on from the front crazydog General Hardware Discussion 20 11-07-2007 10:07 AM
Touch screen causing PC to not boot? chewEboy Power Supplies 11 05-31-2006 02:58 PM
Help! Monitor (PC to Avic-N1 via RCA) won't display anything after boot up screen! lil' is 300 General Hardware Discussion 6 04-09-2006 02:23 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
