If you have Gigs of Ram try this.
Programs run in RAM run 1000 times faster than off a HD or CD !!!
How about running your OS there !
The way to do this is with a Ram Drive but the one that comes with Windows is too small but
others make bigger Ram Drives that are not expensive.
Ram Drive is software to trick your Computer into thinking part of it's RAM Memory is a Hard Disk
Drive. You must have enough RAM left over to run programs outside the RAM Drive so you might want
to upgrade your RAM Memory.
Once you have a Ram Drive, install Windows on Drive C as normal.
But put IE and OE on another HD.
Then use a Program like Norton's Ghost to Copy your OS to another HD and Burn it (Windows OS) to
CD. Use your Autoexec.bat and or Config.sys Files load the RAM Drive on Bootup and Load the OS
from the CD to the RAM Drive and Execute Win.exe on that RAM Drive to run Windows.
Then do your Windows Update and use that Norton Ghost or other program to Copy the RAM Drive to
HD and or Burn that to CD. You can use you Autoexec or Config to run the Saved OS on the (D:, E,
ect...) HD for those Updates that must be installed alone and rebooted after. Install all your
Programs then save the OS in RAM Drive to CD and your on your way.
You'll also have to do this every time you install/uninstall a Program but you'll also always
have a clean OS on Boot even if infected with a Trojan or Virus.
And the Speed Boost of OS running in RAM has a 4 GHZ Computer run like a 50 GHZ Computer.
Are you a Gammer, do a lot of Multitasking or Audio/Video ?
Then this could be an option for you.
Before shutting down if you want to keep the Reg settings that changed after the OS is installed
you just copy your Registry again and import it back to Windows in the RAM Drive if you don't
want to Burn it to CD. If you install a new Program you'll want to do this so you can Burn a new
OS CD with the new Registry or just import it when you want to use that program.
When you reboot you install a Fresh OS each time making it very hard for a Virus or Trojan to
take hold. You can still get infected by user error but it's much easier to clean when you cut it
out of the OS.
Always use a Firewall and if on a Broad Band Connection get behind a NAT Router even if you have
only one Computer. It's better than a Software Firewall but I'd still use one with the NAT
anyway.
Hope this is of interest to you.
Good luck.
Kevin
SOURCE :
http://osdir.com/ml/mozilla.accessib.../msg00015.html
hopefully that helps all that are trying to do this
