Go Back   MP3Car.com > Mp3Car Technical > General MP3Car Discussion
Old 07-12-2009, 11:20 AM   #1
smhussain is an unknown quantity at this point
Need a carpc case which can fit 3.5" hard drive and dvd Rom
I need a car Pc Case which can fit 3.5" hard drive and dvd rom. I have a m2-atx power supply thanks.
My only limitiation is that i want an extremely light and small case as my mother will have to bring it from usa to Pakistan.
smhussain is offline   Reply With Quote
Old 07-15-2009, 07:02 AM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
It all depends on the rest of the hardware you intend to run. What formfactor is the motherboard? miniITX? microATX?
Do you have or need any PCI cards?
I would look at HTPC cases or a cube-style case, perhaps.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Last edited by Enforcer; 07-15-2009 at 07:18 AM. Reason: Remove quote of deleted post
Old 07-15-2009, 02:43 PM   #3
Here are my detailed spec's:
3.5 inch hard drive
3.5 inch dvd rom
m2-atx power supply
Just need as small as possible pc case
Last edited by meddler; 07-15-2009 at 06:53 PM. Reason: removed reference to things that go boom.
Old 07-15-2009, 03:33 PM   #4
3.5 inch hard drive
3.5 inch dvd rom
m2-atx power supply
Just need as small as possible pc case so that my mother can carry it from usa to pakistan.
You haven't answered any of the questions, really.
You need a whole PC case, right? Well, the PC is more than just a HDD, power supply and optical drive. If that's all you have, then carry it all in the original packaging and be done with it.
For a PC case, you need to know the formfactor of the motherboard. KNowing the CPU is helpful also, as some CPUs require more cooling than others, and you would need room in the case for a CPU cooler as well as adequate airflow to bring in cooler air and exhaust warmer air.
And, for the record, optical drives (CD, DVD, Blu-ray) are 5.25", not 3.5".
Old 07-16-2009, 12:33 AM   #5
Detailed Pc Specifications:
Sorry accidentally edited out motherboard information from the previous post. However.
Intel D945GCLF mini-ITX Atom 1.6Ghz Motherboard
3.5" hard Drive 500 GB WD
5.25" Dvd Rom (Normal Desktop Type)
512 MB Ram (Regular Profile)
M2-Atx Power Supply.
FAQ: How to install a DVD R/RW in your Xenarc 700IDT cdcamaro9534 The FAQ Emporium 28 12-10-2007 01:34 PM
WTB: VIA, Case, Hard Drive, DVD, AcuraCl1 Classified Archive 5 02-24-2006 03:07 PM
Dvd and hard drive on same cable question zetecdan General Hardware Discussion 3 07-07-2005 01:16 AM
