Go Back   MP3Car.com > Mp3Car Technical > General MP3Car Discussion
Old 07-25-2009, 01:11 AM   #1
trader007 can only hope to improve
question about various power-on methods
right now i have my remote line for the m2atx hooked to the accessory wire, that way i can hit my remote car starter and my pc turns on (sometimes i want to fire it up and update files). but there are also times when i am sitting in my truck and i just want to have acc on, which means the pc cant turn on. having the ignition on creates twice the load on the battery then it does with it just on acc.
i cant think of anything that is 12v+ on when the remote starter is on and the acc too.. because the acc just turns on the radio and the remote start does not. and i dont want the radio to turn on with the remote start either...
trader007 is offline   Reply With Quote
Old 07-25-2009, 08:25 AM   #2
colin's Avatar
colin will become famous soon enoughcolin will become famous soon enough
Well, your options are:
1) Hack away at the ignition lines. A buddy of mine did this actually. Basically, there are like 4 different ignition wires in your car, but they all go on for the same key positions. You can re-wire your ignitions such that only your radio goes on with ACC1, and during RUN, it all goes on. Then cut the ignition that goes to the computer, and set it to go on only with the remote start and RUN. You'll need to diode isolate them, but it works. My friend has it so that the FAR back position (ACC on most cars) is where you insert the key. Then the old LOCK position is now one where the front speakers and radio turn on. The next step turns everything on, and the next step is for the starter. It's weird having to turn the key and then press it in and turn farther, but it works.
2) Use a simple rocker switch. If you run your ACC wire to a switch and the other side to your outputs separately, you control what goes on and when. That's what I do. Sometimes I'll want music but no screen -- easy. Sometimes I want speakers but no bass -- easy. Sometimes I want no computer -- easy. See my point?
2001 Mustang Convertible Worklog
Indigo Custom Frontend (Flash/Delphi)
Blog
Code:
Currently: - Working on my new product! Wiring: |■■■■■■■■■■■■■■■■■■--| Trunk: |■■■-----------------| Sound: |■■■■■■--------------| Screen: |■■■■■■--------------|
colin is offline   Reply With Quote
Review: M4-ATX 250 Watt Intelligent Power Supply Bugbyte The Review Palace 10 11-17-2009 10:32 AM
2007 Ford Fusion Carputer (version 2.0) FusionFanatic Show off your project 43 04-20-2009 05:56 PM
Inspiron 8500 Power Question joshh385 General MP3Car Discussion 73 06-14-2007 08:27 PM
N00b Power Question jamiewhittingha Power Supplies 15 03-25-2005 01:08 AM
Noob question about power supplies Jagojon3 Newbie 10 03-09-2005 12:35 AM
