08-15-2009, 09:03 PM
#1
Need solution for lack of power and IDE ports.
Hardware in question: DG945GCLF, M2-ATX, IDE laptop drive
I just sold my M10000 motherboard and M1-ATX and bought this new motherboard and power supply. I'm trying to put everything together today but I have a few problems.
Problem 1: There is only 1 LP4 power connector on the power supply, the other 2 connectors are SATA. I have to use LP4 power connectors to power my Xenarc 700TSV and my IDE hard drive. How do I work that?
Problem 2: It appears that since I changed to a 64 bit board and processor that my hard drive will no longer boot on the bench. I get a blue screen that I know is a result of the architecture mismatch. So now I need to reinstall Windows which means hooking up a CD drive. I have an extra drive here but it's IDE and there's only 1 IDE port on the motherboard. I need to hook up this CD drive and my hard drive to IDE. Can I use another 64 bit motherboard I have to install Windows and then swap it back?
Am I better off just buying a SATA laptop drive to solve both problems?
Ampie Case
256 MB DDR2 PC5400
Xenarc 700TSV - VGA Monitor
Intel D945GCLF Motherboard
M2-ATX-HV
2005 Honda Civic
08-15-2009, 09:50 PM
#2
North of the land of Hey Huns
Problem 1: LP4 Y adapter, sold at your local rat-shack (radioshack, or other electronics type store)
Problem 2: Known issue with windows, you can't install on one motherboard and move to another. To reinstall: dual device IDE cable SHOULD work. Make the HDD master and the CDrom slave.
Yes, you're better off buying SATA, but there are solutions if you wish to stick with IDE
RevFE - Try it, you just might like it.
Carbon - Next Generation Touchscreen Browser
Come join us on IRC: irc.efnet.net #mp3car
Audiophiles make me chuckle as they pad my wallet.
08-16-2009, 12:29 AM
#3
I just realized I won't be able to hook up a dial IDE cable because the connector on the hard drive is a mini connector while the other end is a normal size. I don't have any dual cables like that. I'm trying to work with what I have which is a box full of regular computer parts.
Ampie Case
256 MB DDR2 PC5400
M2-ATX-HV
2005 Honda Civic
08-16-2009, 01:38 AM
#4
Fusion Brain Creator
Well I have a quadrillion Y adapters. Actually I will be driving northwards Tuesday, probably be in the Toronto area Wednesday night and all day Thursday this week if you need me to give you one.
Also every geek should have IDE converters, external enclosures, that sort of thing.
Anyways, the easiest way to install windows in your case, is to hook up your harddrive to another fully functional NT based computer as a slave (basically just another drive, not bootable drive). Then format your drive (a quick NTFS format will be fine unless you know there are bad partitions that a full format's MBR indexing will help with). Now assume D: is your CarPC harddrive you just formatted, and E: is an optical drive with the XP CD in it. Type the following into the command prompt (needs admin privs under Vista)
Code:
E:\I386\winnt32.exe /syspart:D: /tempdrive:D: /makelocalsource /noreboot
XP Setup will startup, choose Full Install, go through the rigamaroo, and type in your CD key. After that, it will take some time and it will start copying files and such. When the XP window disappears and shows you your regular desktop, then you can power down your host computer, remove the CarPC drive, and put it in your new PC. Start it up, and XP installation will resume.
It basically does all the setup from the blue loading screen, EULA, CD Key, and copying all files until it says "remove disk and your computer will reboot in 15 seconds" and counts down. So all you are doing is saying do that part, but leave it alone when you are done. Then when you put it into anything else, it starts right back up like it was there the whole time. Simple trick.
And if you dont want to buy Y-adapters you can just hack up some clips from a donor PSU and solder them into your CarPC's PSU. Really doesn't matter.
EDIT: Nevermind, I see you are in Calgary. I thought you were in Toronto for some reason... Rest of it holds true though
08-16-2009, 05:05 PM
#5
So I've resorted to the following:
- I just bought a LP4 power splitter in case I don't end up getting a SATA drive.
- I rounded up a 80 gig SATA laptop drive for $15, supposed to be picking it up tonight.
- I'm creating a .iso image of Windows XP, using my Ubuntu bootable USB creator to turn my USB stick into an installer, going to plug that into the machine and hopefully eliminate the need for the CD drive. I'll install Windows to the IDE drive for now in case I don't get the SATA drive tonight for whatever reason.
Ampie Case
256 MB DDR2 PC5400
M2-ATX-HV
2005 Honda Civic
08-16-2009, 05:07 PM
#6
Well that didn't work, I should have known Microsoft would find some way to **** me off.
Ampie Case
256 MB DDR2 PC5400
M2-ATX-HV
2005 Honda Civic
08-16-2009, 05:08 PM
#7
That's unfortunate, I tried installing from a USB stick a while back and had no luck either.
08-16-2009, 05:16 PM
#8
I've installed from USB stick before, but it is extremely slow.
I'm telling you the easiest way is just put the drive in a host PC and start installation like I mention, then move it back. Works everytime and is very fast since it is internal transfer speeds, not USB conversions.
08-16-2009, 07:09 PM
#9
Well that's how I installed Ubuntu on this laptop I'm using, it was from a USB stick. But Microsoft must have done something with their CD to make it so you couldn't do that with the .iso image. All other .iso worked fine for me in the past.
Sorry, I should have explained to you why I didn't use your idea. You said I need another NT based machine. I got 5 computers and all of them run Ubuntu except my car computer. Don't have another Windows machine unfortunately.
Ampie Case
256 MB DDR2 PC5400
M2-ATX-HV
2005 Honda Civic
08-16-2009, 07:19 PM
#10
Well these are the headaches you get when you go away from M$.
You could always download the XP floppy install which does the same thing but with 10-14 floppy diskettes.
08-16-2009, 11:41 PM
#11
Got the SATA drive, XP is installed, updated and I'm currently stripping it. Problem solved.
Ampie Case
256 MB DDR2 PC5400
M2-ATX-HV
2005 Honda Civic
08-18-2009, 10:08 PM
#12
I've resorted to making my own male-male P4 connector since no stores around here even carry them. Guess where I'm ghetto rigging the parts from.....
1. I got an old *** ATX power supply out of a desktop machine at work that they were going to throw away only to get it home and find out it doesn't work. So I'm going to cut off one male P4 connector from there.
2. I have an old 120 watt amplifier in my closet that (for some reason) has a P4 plug in the side of it and wires hanging off of it. This will be the other end.
So there you go, solder them together and I got a cable!
Ampie Case
256 MB DDR2 PC5400
M2-ATX-HV
2005 Honda Civic
08-18-2009, 11:38 PM
#13
Wait, now I have a problem. When I solder the wires together, do I match them or switch the wiring?
Wire 1 goes to the top left hole on the P4 on one side, do I wire that to the top left of the P4 on the other side? Or top right?
Ampie Case
256 MB DDR2 PC5400
M2-ATX-HV
2005 Honda Civic
08-20-2009, 05:00 AM
#14
wire the two connectors exctaly the same otherwise you will hae some nice bangs from your motherboard
08-28-2009, 01:38 PM
#15
The install of XP running on my carputer (Atom330) was initially installed on a computer running an AMD uATX board. No component in the carputer was previously in that system when first installed.
| Thread Tools |
| Display Modes |
Linear Mode
