Go Back   MP3Car.com > Mp3Car Technical > General MP3Car Discussion
Old 08-17-2009, 09:18 PM   #1
Sbushel7 is an unknown quantity at this point
Thumbs up First Car PC Dilemma
right, i have been on this forum a while now and am looking to very soon install my first carputer
i was just about to start making it all when i had some thoughts..
firstly i will tell you my original idea..
'as i have a broken screen laptop i was going to use this as the pc (the insurance company are buying me a new one ) and have a 7" touchscreen in the dash, have it all under the passenger seat with usb ports in the glove box and the aux out of the laptop going to the aux in on the rear of the head unit, with both the screen and the laptop wired up to the battery'
then i thought about the laptop battery draining severly if i forgot to turn it off so thought what about hooking up the charger + screen to the ignition, then it could run off the laptops battery power and avoid a flat battery
then i thought about a possible power surge when i turned on the ignition and now am really confused.. dont know what to do lol
well anyway i want it as cheap and as effective as possible and have approx £430/$703 to spend on the whole system (except obv the laptop unless you think it would be better if i got a normal pc)
all suggestions welcome and extremely appreciated
thanks in advanced
Sbushel7 is offline   Reply With Quote
Advertisement Sponsored links
Old 08-24-2009, 11:57 AM   #2
soundman98's Avatar
soundman98 is a jewel in the roughsoundman98 is a jewel in the roughsoundman98 is a jewel in the roughsoundman98 is a jewel in the rough
look in the laptop section to see what others have done for your issues--i know that are alot of laptop users that have run into the simmilar problems--i don't use a laptop, so i can't help you much..
soundman98 is offline   Reply With Quote
Old 08-27-2009, 05:58 PM   #3
awuser896 is an unknown quantity at this point
How about if u just set your OS to go sleep after an hour when on battery power?
awuser896 is offline   Reply With Quote
Old 08-28-2009, 03:20 AM   #4
rodweb is an unknown quantity at this point
Check my worklog for a laptop install. No pics of it, but I opened the laptop case and soldered wires from the power switch to the modem phone connector.
I plugged in phone cable with a momentary press button switch on the end of the phone wire. If you get the right power supply (eg. Opus with Laptop firmware or a Carnetix, it can also get wired into this cable to do the startup and shut down.
Didn't take long and I found the manual on Google to show me how to pull the case apart.
RodW
2007 Toyota Hilux with a CarPC..
Worklog: http://www.mp3car.com/vbulletin/work...ota-hilux.html
OziExplorer GPS Embedded in RR: http://www.mp3car.com/vbulletin/sb-s...iexplorer.html
rodweb is offline   Reply With Quote
Old 08-31-2009, 11:58 AM   #5
Hey,
yeah i know about extending the power button but just want a power supply setup that wont do any damage to my car..
what power supply would you reccomend?
Old 08-31-2009, 01:23 PM   #6
sergatiuk's Avatar
sergatiuk has a little shameless behaviour in the past
i used a lappy in my project.
set it to hibernate on 1 min on battery, this way u never drain the battery, u only use it to hibernate. there is also a small program available that can run as a background service to hibernate the comp once the power is unplugged (thats what i use).
then all you need is a relay module to press the power botton on ACC or IGN which will resume it from hibernation, this way you completely automate the power up/down proccess.
sergatiuk is offline   Reply With Quote
Old 08-31-2009, 01:25 PM   #7
Punky is on a distinguished road
there are advantage to both, the PC or the Laptop,
but i you want to use the laptop route, you can buy/build the laptop startup/shutdown module designed by one mp3car member. Then power everything off of an inverter (screen and laptop). Some inverter have ignition wire to tell it to turn on or off when the car is on, some don't. If it doesnt have it, just wire it to the 12V cig adapter, and it'll be on if the car is on. This way you will never drain your batter.
If you want a PC route, mp3car has really nice starter packages, have a look at the store.
Punky is offline   Reply With Quote
Old 08-31-2009, 01:36 PM   #8
sergatiuk's Avatar
i completely agree with Punky, however even if the inverter doesnt have ign wire just connect it to a high amperage wire that is turned on after or on ignition... i connecte3d my inverter to the THICK ECU wire.
this way the inverter powers the laptop on IGN, however the relay module will turn the lappy on ACC this way i can run the lappy using its internal battery without draining the car battery.
Old 08-31-2009, 04:16 PM   #9
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Bugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to behold
Inverters will work but you can also use a laptop power supply that is intended to plug into the cigarette lighter. Those are built to work with car power systems and won't damage the laptop. In addition, they are DC-DC which are often less prone to interfering with the audio.
Want to:
-Find out about the iBug?
-Stop being a newbie? Take a look at the FAQ Emporium?
-Help me kill my car PC
-Watch live video streams from my mobile PC? Check it out here.
-Where is the iBug?
Bugbyte is offline   Reply With Quote
Old 08-31-2009, 04:35 PM   #10
sergatiuk's Avatar
good point bugbyte, in addition dc-dc inverters are more efficient.
their only drawback is the price, which is around $70-$120...
i picked up my 200watt dc-ac inverter for $25 at walmart...
