Go Back   MP3Car.com > Mp3Car Technical > General MP3Car Discussion
Old 08-28-2009, 12:34 PM   #1
nobb will become famous soon enoughnobb will become famous soon enough
High current detachable power connector? To hook up car to house power.
Just a quick question, Im wondering if anyone knows of some sort of quick connect high current plug/connector that I can use for 12V? Sort of like the 120vac plug you have at your home, but for high current (20amps+), 12 volt use, and can resist the outside elements. I searched eBay, but Im probably not using the right terms.
The reason why I want to do this is so I can have a single connector that I can plug my car's electrical system into a 12 amp battery charger for when I am working on the carpc or whatever which may drain the battery. Right now, every time, I have to pop open the hood, disconnect some bolts, and clamp on the battery charger to both my main and auxiliary battery. Too lazy for that =)
nobb is offline   Reply With Quote
Old 08-28-2009, 01:07 PM   #2
fixerofallthing's Avatar
fixerofallthing is on a distinguished road
http://www.truckntow.com/pc-23104-14...omponents.aspx
This is what they use on tow trucks. It is expensive but gives you an idea of what to look for on ebay. If you can get just the grey connector you can convert your battery charger over and never have to lift the hood again. Just an idea. Hope it helps.
The Car 2005 Scion xB
The Truck 2004 GMC Canyon
fixerofallthing is offline   Reply With Quote
Old 08-28-2009, 01:16 PM   #3
mstaedt's Avatar
mstaedt is an unknown quantity at this point
Anderson connectors. Lots of sizes and colors
http://www.andersonpower.com/product...powerpole.html
Project completed! (almost)
My Truck as featured in Custom Classic Trucks magazine.
mstaedt is offline   Reply With Quote
Old 08-28-2009, 01:20 PM   #4
soundman98's Avatar
soundman98 is a jewel in the roughsoundman98 is a jewel in the roughsoundman98 is a jewel in the roughsoundman98 is a jewel in the rough
exactly what i was going to recommend(if you look at the first link, it has the same style connector, but has 2 connections) -- there are many different companies that sell these, most of them are industrial supply houses-- for an idea where to look, these are commonly used to charge motorized pallet movers/electric fork lifts.
soundman98 is offline   Reply With Quote
Old 08-28-2009, 01:22 PM   #5
bemenaker's Avatar
bemenaker is on a distinguished road
I've run my CarPC for around five or six hours without the engine running and still been able to start my car afterwards.
bemenaker is offline   Reply With Quote
Old 08-28-2009, 02:20 PM   #6
Jershell99 is an unknown quantity at this point
I have used the same plugs that are used in trailer plug wiring, but they are available in 2 pin configurations.
Those anderson plugs look nice!
Jershell99 is offline   Reply With Quote
Old 08-28-2009, 02:27 PM   #7
North of the land of Hey Huns
malcom2073's Avatar
malcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to all
You could use a NATO plug/receptacle. It's a bit expensive, but definitely durable and easy to connect/impossible to hook up wrong.
RevFE - Try it, you just might like it.
Carbon - Next Generation Touchscreen Browser
Come join us on IRC: irc.efnet.net #mp3car
Audiophiles make me chuckle as they pad my wallet.
malcom2073 is offline   Reply With Quote
Old 08-28-2009, 08:19 PM   #8
trader007 can only hope to improve
i plan on getting an automatic charger i can leave hooked to my battery, with just the plug hanging out the grill. plug and charge anytime you want. this is the charger im looking to get- http://www.batterystuff.com/battery-...s/GU2612A.html
trader007 is offline   Reply With Quote
Old 08-28-2009, 09:21 PM   #9
Wow $100 for that TrucknTow product? Maybe I should just buy some industrial grade 120VAC plugs and DIY modify it for 12v instead.
Old 08-31-2009, 07:02 AM   #10
mstaedt's Avatar
They are nice. They attach to each other on the sides so you can create any type of modular connector.
Old 09-04-2009, 11:06 PM   #11
jeffeulogy is an unknown quantity at this point
a decent electronics store should carry the anderson sb-175, which is probably the connector pictured in your link (might be a larger size) i used them to build a pass through adapter to run a radio on my pallet jack at work. the're rated for 175 amps at 24v and shouldn't run you more than 10 bucks each.
jeffeulogy is offline   Reply With Quote
Old 09-04-2009, 11:10 PM   #12
Thanks for the suggestions. While we are on the topic of hooking up the car's electrical system to the house, is it safe for the alternator to remain connected? It should have diodes to prevent back emf right? aka. current going into the alternator.
Old 09-07-2009, 06:49 PM   #13
yes they must have that feature or it will pull enough current from the car's battery alone to flatten it in a few hours. this happens with bad or broken alternaters sometimes.. the diodes burn out and you always wake up to a dead battery in the morning.
may i ask again why an onboard charger wont work?
Old 09-07-2009, 06:54 PM   #14
Ideally, I would love for the charger to be onboard. But unfortunately my battery charger is huge (volume of a big shoebox) and I have no where in the engine bay to mount it. Unless someone knows of a 15+ amp high current charger that is also very slim and compact.
Trader007, the charger in your link is only 10amps and costs $120. I could get two 12 amp chargers from Canadian Tire for the same price =)
Old 09-07-2009, 07:32 PM   #15
PaulF's Avatar
PaulF is on a distinguished road
What are you driving? You could always put the charger in the trunk if it's not a pickup.
My Car (Just the audio install as of now)
http://paulfurtado.com/car/
Worklog:
http://www.mp3car.com/vbulletin/work...-work-log.html
Planning 90%
Computer Build 88%
Programming 10%
Car Install 71%
PaulF is offline   Reply With Quote
VW Jetta dMand Show off your project 88 11-16-2009 08:43 AM
Please commont on a n00b's design idea of a do-it-yourself car audio system Zta Newbie 5 03-06-2009 05:15 PM
Hardware Review: M3-ATX Power Suply Bimmerstyle The Review Palace 8 03-05-2008 06:57 PM
NIB M2-ATX DC-DC ATX auto car PC power supply mini ITX EPIA ichiban Classified Archive 6 07-21-2006 01:00 PM
What to look for in a PSU some info for you cproaudio Power Supplies 9 04-04-2003 02:07 AM
