the way i have always looked at it, raid is mostly for drive failure where the drive contains extremely critical information. a carpc is defined by running a computer in a environment that it was never meant to run in, and none of the information contained on a carpc, IMO, should never contain critical information.
there was a thread awhile ago on different types of hdds, and what was the 'best' hdd type. the thread went back and forth, but finally came to a consesus that a ssd drive was slightly better than 2.5" hdd, and that was slightly better than a 3.5", but none of the drives are perfect, and if you value the info on the drives, constantly back it up or image the drive, and keep the backup/image in a safe place, or multiple places.
the reality is that mobile environment is a horrible environment to put unsealed electronics like motherboards or hdd controller boards in, and a raid array could only give you a false sense of security, only to have both drives fail after a water leak, spilled drink, or a electrical surge...
also, the one thing i don't like about bootable raid arrays is that if a new driver corrupts the OS, you have no choice but to reload the whole system, or try to recover it in safe mode-- your other raid drive also copied the corrupted file after all...
but, if you were to take constant backups/images of the drive, you would be able to revert to the most recent backup, possibly saving alot of time, and stress.
i honestly just do not see a reason to build a super powerful computer for a car-- my system with a 1.2ghz atom dual core, and 2gigs of ram is more than enough--and i am doing more audio processing than your standard system(i could deffinitly downgrade to 1gb ram)
