Quote: Originally Posted by
kross
The obvious (and easiest) solution is a boom box.
being that he is asking, i am going to assume that he doesn't want a store bought solution...
i have made a couple a while back--you really have 2 options, you can either use a computer power supply, or a 12 volt battery with a charger. the advantage to the computer power supply method is that they are cheaper, and the battery and charger is going to get heavy if you want decent run times.
the advantage for the battery design is that you will be able to run it for a while without any cords. the computer power supply would need a power cord run to it.
once you have your ideas for how to power it, your design is only limited by space, time, and money.
i built mine out of a single speaker box that i found at a thrift store, a old car audio amp,and computer power supply-- i have not yet integrated a radio into it, only using it for a 'portable' ipod speaker.
