Quote: Originally Posted by
Punky
only issue is HD really, get the automotive grade HD from mp3car store, and you should be ok. SSD is a possibility and it is currently being tested by a few mp3car members including myself. Result won't be out until the end of this winter of course.
Not really anything to "test" here the manufacturer already did.
The screen really isn't much of a problem other then not being able to use it (the remote starter was a good suggestion). But firing up a hard drive in those temperatures can actually cause permanent damage so that may be the thing that needs swapping out. Most regaular hard drives are rated for 5-55°C which would obviously be a problem in the temperatures your dealing with.
Just look at the specs for a SSD before you buy one but a lot of them are rated -40°C to 70°C. Big difference.
