Go Back   MP3Car.com > Mp3Car Technical > General MP3Car Discussion
Old 10-22-2009, 01:03 PM   #1
mm87 is an unknown quantity at this point
monitor power cord crapped out
on my Xenarc 700 idt. i was using the one that plugs into the cig lighter and it just decided to stop working. i tested the monitor and the cig lighter and both are good.
any ideas as to where i can get another one of those?
or if someone could tell me how to hardwire it into my vehicle as i lost the manual for it
mm87 is offline   Reply With Quote
Old 10-22-2009, 02:15 PM   #2
jessekilner's Avatar
jessekilner is an unknown quantity at this point
Im betting there a fuse inside the barrel of the lighter plug. If not I had the same issue with a liliput and had to cut the end off and inside there was a red and black wire.. the plug had split in it from removal and install alot..hope this help
the end of the barrel should unscrew and out comes a tube fuse which im almost certain is blown.
Did it.. Done it... now I got to keep the neighbors kids away!!
jessekilner is offline   Reply With Quote
Old 10-22-2009, 05:27 PM   #3
i didnt look so i dont know of its the fuse or not but, if it is why would it blow?
i ended up buying one of those universal ones from radioshack for 16 dollars
Old 10-22-2009, 09:09 PM   #4
it could blow for many rmber reasons. but it always boils down to too much draw. its possible it has a split in wire and shorted the fuse. IM guessing the new barrel plug worked. Either way glad it was a easy fix.
Old 10-22-2009, 09:27 PM   #5
yup good to go thanks for your help
Where to find high quality Aux shielded patch cord? audiology General MP3Car Discussion 0 12-20-2007 10:34 PM
Power Cord question Speg Power Supplies 0 05-19-2005 09:22 AM
Lilliput Cord tczbu General Hardware Discussion 1 01-25-2005 01:24 PM
tsv700 DigitalWW in-dash power cord connection question TheBigDog General Hardware Discussion 0 08-30-2004 08:40 PM
How to wire a laptop lcd to vga cord? acebrooks44 Newbie 5 10-09-2003 09:13 PM
