hello, I hacked a relay into to my power button on my laptop but while testing it I noticed the ACC cable doesn't have power when the car is cranking.
the means as the turn the car on I go past ACC and the ON position which closes the relay, starting the computer. then the engine cranks which opens the relay (computer still starting) then the key goes back to the on position which closes the relay again causing the computer to shut down again.
do you guys hook up your carputers without this problem?
thanks!
-Dan
