Go Back   MP3Car.com > Mp3Car Technical > General MP3Car Discussion
Old 05-27-2004, 09:47 PM   #1
CPU woes - What do you guys think?
Now my old home PC has been getting progressively slower and slower so I decided to do some performance tests. Now this PC has a 550Mhz AMD K6 processor. Can you guys tell me what you think about this?
That is supposed to be my processor speed in real time at the bottom right corner
http://images.cardomain.com/member_i...8_151_full.jpg
95 Toyota 4Runner
Elliott's MP3 Runner
Components of my setup takes up way more than 250 characters and no matter how I tried to make it fit here it just wouldn't so please check my page.
Dluvr22 is offline   Reply With Quote
Old 05-27-2004, 11:50 PM   #2
eCar™'s Avatar
I'd say that it's probably off a bit. Usually WCPUID is pretty accurate. But in your case, I think it missed by a few.
eCar™ is offline   Reply With Quote
Old 05-28-2004, 01:28 AM   #3
That is quite a few. I am almost certain my pc is not running at .52 mhz. Could it be a motherboard problem? I put the same processor in another PC and it was a lot faster however I did not run any tests on that pc to know the exact speed.
I don't know if it has anything to do with my clock speed but as you can see in WCPUID, it happens to be .23 Mhz. What's up with that. I thought it shuld have been 100 Mhz.
95 Toyota 4Runner
Old 05-28-2004, 01:36 AM   #4
eCar™'s Avatar
I don't think it's a problem with your mobo. You can't be running at 0.54MHz.
When you say it was faster in another PC, what are you judging it with? Just WCPUID? Or are you noticing better performance with applications or games?
Old 05-28-2004, 03:16 AM   #5
the slowerness is probably due to windows committing suicide after some time being installed (the registry grows forever and the stupid functions that access the registry only know how to scan in a linear fashion)
as for the 0.54MHz, I'd say this is a stupid typo, where they meant GHz...
I don't need no stinkin' startup-shutdown controller... That's what journalized filesystems are for...
NavSys, the ultimate navigation app
http://www.navsys.org/
sxpert is offline   Reply With Quote
Old 05-28-2004, 11:43 AM   #6
I notice a lot better performance.
i.e. When you clikck on the start menu in windows it takes approximately 10 seconds to pop up whereas in the other PC it pops up immediately.
Everything else it does a lot faster.
95 Toyota 4Runner
Old 05-28-2004, 11:49 AM   #7
It has not been a long time because that thought crossed my mind so I backed up everything and reformatted the hard drive 3 days ago and reinstalled XP Pro. Still the same thing.
As for the Mhz, it is not a typo. I overclocked my M10K and it now runs at 1216.42 MHz
95 Toyota 4Runner
Old 05-28-2004, 12:05 PM   #8
eCar™'s Avatar
I find it hard to believe you could run at all, if that was the actual processor speed.
It does sound like there is a problem if you're waiting 10 seconds for the start menu to come up.
Try some other system benchmarks. These two may give you some more clues:
Run Full Test at PCPitstop.com.
A more advanced sys info app is Sandra2004. The standard version is free.
Old 05-28-2004, 12:48 PM   #9
You're not supposed to overclock these things (is there even a way to do so ?)
FS: 2 80GB 7200rpm Hard Disk & Zalman CPU Cooler ashbosh Classified Archive 10 05-24-2004 11:10 AM
Mobo Woes - Enlightenment needed nzKAOSnz Off Topic 0 05-17-2004 09:24 PM
Need more CPU power NewTechFool General Hardware Discussion 0 04-29-2004 05:10 PM
CPU Heat question: Which one would generate less heat? kiztope General Hardware Discussion 6 02-12-2004 03:14 AM
CPU Cooling Dartman111 General Hardware Discussion 5 06-04-2001 02:56 PM
