Go Back   MP3Car.com > Mp3Car Technical > General MP3Car Discussion
Old 06-06-2004, 01:27 AM   #1
C4M
C4M's Avatar
C4M is on a distinguished road
Encoding options research
Recently, there has been much talk of FLAC, and the fact that it may well be the new saviour for compressed music. Read more about the project here.
I decided to do a little testing this afternoon. Using my Living Colour CD - Stain, I ripped tracks 8 & 9 (Nothingness & Postman) four times, to the following formats, using the listed options, which resulted in the shown file sizes:
Track 8 - Size(Kb) - Quality
WAV - 36,452
MP3 - 6,425 - VBR-MTRH, quality=0(best), Lame Encoder
OGG - 4,226 - Q=0(best) min=80, max=350
FLAC - 24,140 - Q=8
FLAC - 25,661 - Q=0
Track 9 - Size(Kb) - Quality
WAV - 36,378
MP3 - 6,960 - VBR-MTRH, quality=0(best), Lame Encoder
OGG - 4,216 - Q=0(best) min=80, max=350
FLAC - 27,010 - Q=8
FLAC - 28,553 - Q=0
Testing method
I used CD-ex for all except FLAC; for FLAC I used FLAC 1.1.0 with the windows frontend. For playback testing, I used Winamp 5, with the FLAC plugin added. Testing was performed blind - in other words, I couldn't see from the playlist which version of the track that I was listening to.
Winamp was configured with the EQ turned off, and to a relatively low volume. Loud subjective testing makes for short subjective testing.
Discoveries
Size
First observation was that the FLAC files were significantly larger than the lossy compression files. Although HDD's are cheaper these days, the FLAC files are approximately 6 times the size of the OGG files. I was surprised at how large the FLAC files were, so I ripped the WAV's again, this time at Q=0. Still a very large file compared to OGG & MP3.
Volume
I did my listening using my PC, with crappy 2.1 computer speakers - all tracks were played back through the same system, at the same volume. There was no discernable change in volume from one track to the next; that is - all encoding methods output tracks at the same volume level.
Sound quality
It was pretty easy to determine which were the lossy compressed tracks, and which weren't.
It took me a little while to decide (and numerous repeats) that there was a winner from the lossy compressions - it turned out to be OGG. However I couldn't tell the difference between the FLAC and the WAV file.
Conclusions
  • My wife is completely over the first verse of each of these tracks
  • OGG was noticably better than MP3
  • FLAC and WAV are virtually indistinguishable
Now - my objective from this test was to figure out whether FLAC was all it is cracked up to be. It is. Better than OGG and MP3? No doubt.
I don't know whether I can stomach the file sizes at this stage though. Having said that though, I'll be looking to encode from this point using OGG rather than MP3 - the difference was that noticable. Bonus is that the files for OGG are smaller again than MP3.
The only trap is that the new sound system in the car may show up some of the deficiencies of compressed music. Time will tell.
Hope this is useful to someone. Has anyone else done testing of this nature?
C!
http://carpc.riposte.net
I reserve all rights in connection to each post I author, without exception.
C4M is offline   Reply With Quote
Old 06-06-2004, 05:11 AM   #2
starfox's Avatar
starfox
There was a post about something similar to this on slashdot a couple of weeks ago pointing to this site:
http://www.rjamorim.com/test/multifo...8/results.html
Though this is just a comparison for 128kbits/s recordings, it notes that there's a japanese programmer that's tweaking the settings in vorbis that gives better results than stock vorbis so you might want to try use that instead.
FLAC is lossless compression, so it should be bit for bit with the original wave file once you decompress it. As you said though, it makes rather large files. If you want a comparison, there's also another codec called Monkey's Audio around which is also lossless and generates slighly smaller files than FLAC (though it takes a bit longer to compress).
I've noticed many many awful glitches while playing MP3s in my car.. loss of stereo imaging, sharp cutoffs with some instruments due to masking, weird sound instruments in some cases (especially quite guitars).. I've been trying to use Monkey's Audio and FLAC where i can now.
I guess car audio is something that perpetually costs more and more money You spend money upgrading your speakers, amplifiers, then you put a computer in to play music. After that you realise that your mp3s all suck, so you spend time reripping them all, and buying a larger hard drive for your car computer..
Then you realise that your cd player at home sucks, so you buy proper amplifiers and proper speakers and spend more money on things like cables and other interconnects.. and it just keeps going and your wallet keeps getting thinner....
starfox is offline   Reply With Quote
Old 06-06-2004, 05:33 AM   #3
Ashlawn Kemling's Avatar
Ashlawn Kemling is on a distinguished road
Yep, OGG is usually the winner for lossy. It does sound so much better. I have compared the difference of 128kb OGG vs. 128kb MP3 and OGG wins hands down. MP3 tends to cut out the highs and make the lows 'duller.'(Quieter?) MP3 is an outdated format and should be trashed. OGG is open source and free. You don't have to pay to liscense it. Only problem is, everyone has MP3's... d'oh!
Ashlawn Kemling is offline   Reply With Quote
Old 06-07-2004, 10:16 AM   #4
Raw Wave
Defiler's Avatar
Defiler is on a distinguished road
Acctually .wma is the hands down winner in lossless compression. It's the fact that the files are too damn big when it's done like that though.
Yes, I am ready to be flamed but try it for yourself and see.
Defiler is offline   Reply With Quote
Old 06-07-2004, 11:30 AM   #5
starfox's Avatar
starfox
But ogg and flac are both free..... free is good ^^
but we all agree that mp3 more-or-less sucks right?
Old 06-07-2004, 11:39 AM   #6
Raw Wave
Defiler's Avatar
So is wma??? Just look in your media player 9 compression options. I'm happy with the size/quality of my 192 lossy mp3 files.
Old 06-14-2004, 03:13 AM   #7
C4M
C4M's Avatar
No - we don't agree. MP3 as a format made some break throughs and paved the way for the other formats that we have available today.
It's more about having an eye on the future, with some respect for what has come before.
C!
Old 02-14-2005, 01:41 PM   #8
kingnasty is on a distinguished road
i respect the model t, but id much rather drive my wrx
should i just google to find more about ogg??
kingnasty is offline   Reply With Quote
Old 02-14-2005, 02:59 PM   #9
rubicon's Avatar
rubicon is on a distinguished road
Umm.. You do understand what a lossess format is, don't you?
I'd be much more surprised if they were distinguishable in any way.
BTW, FLAC 1.1.2 is out.
/dropped mp3 for ogg
//dropped ogg for flac
///HD space is cheap; quality is what matters
EDIT:
You'd probably be better served ripping *once* to a wav, then encoding for each different format. But its your time.
rubicon is offline   Reply With Quote
Old 02-14-2005, 03:03 PM   #10
rubicon's Avatar
In what way? Compression ratio? Decoding speed (since that's what really matters)? The fact that it has "Windows" in its format name?
For all things *except file size* I have to go with FLAC; see the next bit about file size, tho.
Disk space is cheap. Quality is what matters. I'm glad I found digital audio and mp3s oh so long ago, but I haven't encoded anything in a lossy format for a while now - just got a DVD burner and bigger HDs.
Old 02-14-2005, 03:06 PM   #11
rubicon's Avatar
I'm [dimly] aware of buggy whips, but I have no respect for them.
Old 02-14-2005, 03:07 PM   #12
rubicon's Avatar
FLAC FLAC FLAC FLAC!
Old 02-14-2005, 03:13 PM   #13
Raw Wave
Defiler's Avatar
SQ
Old 02-14-2005, 03:16 PM   #14
rubicon's Avatar
SQ
I assume by "SQ" that you mean "sound quality."
When we're talking about lossless compression, sound quality between formats will be identical.
How do you figure wma sounds any better than flac?
Old 02-14-2005, 03:45 PM   #15
Self proclaimed spoon feeder
TruckinMP3's Avatar
TruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud of
MP3 and 100%VBR.... the human ear cannot tell the differance.... Like the old memorex comercials.
TruckinMP3
Read the FAQ!
TruckinMP3 is offline   Reply With Quote
Audio input Options eazyrog Car Audio 10 07-13-2005 02:36 AM
Larger VGA widescreen with touch options Yamato LCD/Display 3 04-05-2004 05:51 PM
motherboard options Quattro General Hardware Discussion 7 12-19-2003 05:54 PM
DivX encoding codec versions and guides magnetik General MP3Car Discussion 11 04-08-2002 04:18 PM
Extra power options? TheDingo Power Supplies 7 06-02-2001 01:19 AM
