Go Back   MP3Car.com > Mp3Car Technical > General MP3Car Discussion
Old 06-08-2004, 03:09 PM   #1
binary.h4x's Avatar
Scuff Marks
Hey guys, I just bought a 95 Saturn SC2. It has some scuff marks on the inside and I have tried everything in my garage short of the powerwasher.
this is my driver's side door. The scuffed material is a molded plastic. Any suggestions on how to get the scuff out?
this is my drivers seat. It is leather, and i think the light spots are just plain worn leather, but i want to know, what is the best way to the the black scuffs out of the leather?
binary.h4x is offline   Reply With Quote
Old 06-08-2004, 03:13 PM   #2
Snootch's Avatar
First I would try a good vinyl cleaner, like Armor-All's Cleaner (not regular Armor-All, a cleaner made by them), and if that doesn't work, then maybe some rubbing compound and alot of elbow grease. If THAT doesn't work, then use some acetone on a rag, then follow up immediately with some water, then Armor-All. That will definately do it, but you run the risk of discoloring the vinyl. The seat you will have to get re-upholstered. it looks like the top surface of the vinyl has been scraped off. I don't think there is anything you can do for that.
WORKLOG
VIA SN18000/1Gb GEIL PC3200/100Gb 2.5"HD/8" Phylon TS/BU-353 GPS/Powermate/M2-ATX PS
Webpage
Snootch is offline   Reply With Quote
Old 06-08-2004, 03:48 PM   #3
DJKhan85's Avatar
if that doesn't work you can try and hit up a junkyard for a replacement door panel or you can buy one from the dealer. as far as the seat goes you might get lucky at a junkyeard with a new seat but for the most part there really isn't anything cheap that will fix it.
DJKhan85 is offline   Reply With Quote
Old 06-08-2004, 04:08 PM   #4
heypachuco's Avatar
On the door panels, you may want to try 409 and a scrub brush. It looks like the scuff marks are from the previous drivers shoes, so they should come off fairly easy. I would not use acetone. It will slightly melt the plastic and leave a dull finish. Also, it will be sticky for a minute or two and will have towel lint all over.
heypachuco is offline   Reply With Quote
Old 06-08-2004, 04:12 PM   #5
binary.h4x's Avatar
i dont think they are in the condition to need replacing yet.
Old 06-08-2004, 04:17 PM   #6
bosstone74's Avatar
I know this is going to sounds weird, but I just did this last night, I was up till about 1am cleaning my car out. Anyway this is how I have been cleaning scuff marks and my leather seats for years... "WINDEX" and a stiff plastic scrub brush. Just scrub and wipe with paper towels. If you are wondering if it has damaged any of my vehicles. I don't think it does. However I drive them into the ground, so I don't know if the 1 inch crack on my dash is from the cleaning or just being 12 years old. The leather seats I sit on are in pretty great shape for being 12 years old too. The passanger and back seats are perfect, and the dirvers seat has my *** worn into it. I'm not recommending it for you... just stating what has work very well for me (and cheap). After I use the Windex, and let it dry I use Armoral to moisten things back up.
BossTone74
bosstone74 is offline   Reply With Quote
Old 06-08-2004, 04:20 PM   #7
Marsupial's Avatar
you might want to simply dye it. There are lots of vinyl dye and you should be able to obtain a good result, but that include redying all the parts to have the exact same color everywhere.
-Mars
Carputer progress meter:
[----------] - 0%
status:
Changing project. The kiosk I have will end up in the kitchen! Reviewing carPC ideas...
Marsupial is offline   Reply With Quote
Old 06-08-2004, 04:26 PM   #8
craashmann's Avatar
Armorall actually takes out natural oils and moisture in plastics, and cause them to crack... It's alright if you keep using it, but when you stop you tend to get the 1" wide crack
Car: 1991 Camaro Z-28 5.0
Computer:
Carputer build 2: In progress - Epia 10000, 5.1 surround sound, front panel replacing 1.5 din radio, laptop or standard hdd???
Future projects: GPS, Reverse camera using 4" monitor, PA System, FM/TV Tuner
craashmann is offline   Reply With Quote
Reading one thread marks all threads/forums read Micahb Mp3car Forum Suggestions/Comments 1 11-11-2002 04:56 AM
