Sorry, started a new thread, old one had too many posts for my ADD brain ;x um....oh yea, i was reading an article about AMP cooling(and amps get way hotter than a computer case) and this guy had an idea to make a box for air flow, take in cold air from 1 location, vent it to another, but control the path of the airflow. See diagram..(<3 paint)
the lines between fans control the air flow. Just have 1 end suck in air from the cabin, another end vent air out the trunk(there should be openings that are closed off with rubber grommets, im sure you can find a pretty way to dissapate the heat, you could even pump it back into the cabin if you wanted to. I dont know, if it works for amps im sure it would work to cool a comp. Feedback please
