Go Back   MP3Car.com > Mp3Car Technical > General MP3Car Discussion
Old 06-16-2004, 04:24 AM   #1
Transferring data between computers
I wanna transfer all my mp3s ( 29 GB's) from my desktop to my carputer. I would like to do this without burning cd's since that would take a lot of time and cds. I can't really do this over the internet since that would probably take longer. How do most people do this?
fraganic is offline   Reply With Quote
Old 06-16-2004, 04:28 AM   #2
FLA
gospeed.racer's Avatar
Personally, I have had good luck with taking the hard drive out of the car and placing it in the master computer as a slave. Drop all the MP3's in the my documents or wherever and go. Then, put it back in the car and your set. Simple and fast. Never tried a data cable but you probably dont have one if you are asking.
00 Focus LX soon to be boosted!
88 Escort GT Turbo DFI
gospeed.racer is offline   Reply With Quote
Old 06-16-2004, 05:35 AM   #3
carpcnoobie's Avatar
Do you have a network? I put mine up on the network (had to transfer music and files from carpc to desktop). My mobo has a built in ethernet connection. I simply took a cable from there to my router, punched in a few things real quick and there it was.
I've also done the method speed racer mentioned and that has worked well also.
Progress Meter:
[|||||!||||'] 95% complete
It's in... it's finally installed!!!! But never finished!
"It works! It works! I've finally invented something that works!" -- Doctor Emmit Brown
carpcnoobie is offline   Reply With Quote
Old 06-16-2004, 06:16 AM   #4
Pokey's Avatar
I just did the 'swap the HD' way yesterday, thats the best for that much memory, anyway else and you'll be waiting along time, like 5 or more hours.
Dual Lilliput's 70NP/C/T
Syntax SV266AD KT266A
AMD Athlon XP 2000
Viking 256MB DDR
D-Link Wireless 802.11B
Seagate 120GB
OrbitMicro 250W DC/DC converter
SII Wireless Audio Link
Digimoto OBD-II
Earthmate GPS
BU-303 USB GPS
D-Link Bluetooth
Pokey is offline   Reply With Quote
Old 06-16-2004, 06:51 AM   #5
Yuriy's Avatar
I just use the network..
00 Saturn SL2, boosted @ 8 psi - CarDomain
Newest install - my quickest ever
My 2nd carputer - b4 I broke the touchscreen
My very first carputer - voted the most ghetto
Yuriy is offline   Reply With Quote
Old 06-16-2004, 07:30 AM   #6
RobMR2's Avatar
i use a Wireless network card here
VIA EPIA MII12000
256Mb DDR333
Western Digital 80Gb
Lilliput 7" Touch Screen
Pioneer Slot Load DVD
PixelView Play TV Pro
RobMR2 is offline   Reply With Quote
Old 06-16-2004, 08:16 AM   #7
Batmanatthenewb's Avatar
My car stays in the garage. Have a wireless network and wired network in the garage. Small files and updates I leave the pc on overnight (hooked to house AC) and transfer through wireless. If I am reloading or transferring a whole bunch of stuff I plug in the wired ethernet, as it is considerably faster. Either way I use Symantec PcAnywhere. Just get it started a night, and when I get up in the morning itis done.
Batman
Batman@TheNewBatcave.com
AMD XP 2000, 1gig PC2700, 80gig 7200RPM HD, DVD CD/RW, ATI All in Wonder 8500DV w/remote, DataChute, IRDA, Wireless 802.11b, cell modem, Lilliput 7" VGA TS, XP Pro, GPS w/Routis
www.samshomepage.net
www.Cars-N-Computers.com
Batmanatthenewb is offline   Reply With Quote
Old 06-16-2004, 08:45 AM   #8
I agree that the best way is to take the drive out of the carputer and put it in the master computer. I have about 80 gigs of MP3s and can transfer all of them in about 45 minutes. To make it ridiculously easy, go to Ebay and buy two identical hard disk trays/caddies. They should cost about $15 each. Install one in each computer. You can then just pull the tray out of the carputer, plug it into the master, transfer the files and plug the tray back into the carputer.
kbreeden is offline   Reply With Quote
Old 06-16-2004, 09:14 AM   #9
fondoo's Avatar
i burn them on a CDRW and transfer the files to my carpc.
fondoo is offline   Reply With Quote
Old 06-17-2004, 09:36 PM   #10
Ok, i tried the HD swap way, but i'm probably doing it wrong. I ran the Carputer HD as a slave off the home HD. I hooked it up while the computer was off, and when i turned on the computer, it said "disk boot failure, insert system disk" or something like that. I have XP on the home comp. and windows 2000 on my carputer, and i don't have a boot disk for either. Is it a problem that they're 2 different OS?
Also, my carpc has an ethernet connection, i think. It looks like a large phone jack right? So could i transfer data through this? Would i need a program to do this?
Old 06-17-2004, 09:41 PM   #11
I use a Firewire 800 drive. 29 Gb should be about 20 min.
Alric is offline   Reply With Quote
Old 06-17-2004, 10:00 PM   #12
more mods's Avatar
You may have them both set to master.
more mods is offline   Reply With Quote
Old 06-17-2004, 10:26 PM   #13
If you are doing a wired NIC to NIC transfer between two host ends, you will need to buy "cross over" rj45 cable. If you buy straight through it will not work, unless the NICS support this.
dignome is offline   Reply With Quote
Old 06-17-2004, 10:53 PM   #14
cadence117's Avatar
I tried doing it wirelessly... but After my battery almost died twice,
I pulled the car up to the window and ran a cable to my router
mobo $130 ; 150wOpus-$200 ; 256mb pc2700 -$10 ; 120gb HDD 7200-$70 ; Lilliput TS 7"-$265 ; USB LAN-Free AR ; Rikaline 6010 GPS-$34 ; ShuttleXpress-$37
Total = $746....Carputer = Priceless
cadence117 is offline   Reply With Quote
Old 06-17-2004, 11:02 PM   #15
BraGa's Avatar
Ok, I use gospeeder.racer way... but the thing is, when I turn the HD back in the carputer, all data i've transferred as gone (I've tried 2 or 3 times)!!! Any thoughts??
Don't eat the flesh where you earn the bread...
BraGa is offline   Reply With Quote
Capture GPS data at the flip of a switch Mr. Inquisitive GPS 4 02-02-2005 07:06 PM
VOICES Traffic Data stevieg V.O.I.C.E.S 85 05-31-2004 09:24 PM
Online Traffic Data (UK) stevieg Software & Software Development 17 04-27-2004 03:14 PM
Cold hard drive fluid bearing data loss Mikesz General Hardware Discussion 2 12-13-2003 08:17 PM
Using a microprocessor to display GPS data on an LCD Zip-Lock GPS 15 10-21-2002 04:06 PM
