Go Back   MP3Car.com > Mp3Car Technical > General MP3Car Discussion
Old 06-25-2004, 06:27 AM   #1
Yuriy's Avatar
Need current to flow one way
I need my current to flow only one way (this is for the laptop/battery setup).
From what I know, I need to use a diode, like this one:
In Russia I would normally just go to the radio market and buy a box of these, but where can I get them in US? Also, I think it might be possible to use the light diode (LED) - do any of you know if it's true?
Any cheap alternatives?
I'm going to disect a few of my old gadgets tomorrow and make my circuit, but I thought I'd first ask the experts what's best.
Cheers
00 Saturn SL2, boosted @ 8 psi - CarDomain
Newest install - my quickest ever
My 2nd carputer - b4 I broke the touchscreen
My very first carputer - voted the most ghetto
Yuriy is offline   Reply With Quote
Old 06-25-2004, 07:15 AM   #2
diodes are quite cheap.
In the US, visit your nearest Radio Shack if you want quick and easy.
LEDs dont work the same way. LEDs will need a resistance in series so it doesnt blow.
Some LEDs are bi-directional if I remember correctly
New Lilliput EBY701 For Sale http://www.nusantech.com/index.asp?c...at=TOUCHSCREEN
SiRF3 Bluetooth GPS http://www.nusantech.com/index.asp?cat=GPS
masch is offline   Reply With Quote
Old 06-25-2004, 07:32 AM   #3
djmickyg's Avatar
you can use an led but u gota rember the led will use some voltage where as the normal diode wont use hardly anything
and u can use a led without a resistor as long as the voltage is right,
djmickyg is offline   Reply With Quote
Old 06-25-2004, 08:12 AM   #4
Yuriy's Avatar
Well, I came up with a solution. I know there are diodes in AC/DC adapters, so I'll just disect a few
Old 06-25-2004, 08:24 AM   #5
b_nom's Avatar
The reason LED's won't work is because they are low current devices (around 20mA) thus the need for a resistor in line for 12V use (around 600ohms resistor needed).
You have to make sure that whatever diodes you dissect are capable of handling the current that's going to pass through them i.e. whatever your system will use, because they could heat up and eventually break down or blow up.
WHen I was in school we use to blow up diodes in the electronics lab to stir up the teacher
'96 Chevy Cavalier - EPIA M10000, Win2K,MediaCar, Deluo GPS Mouse with Routis, 60GB external HD, 7" widescreen monitor from DigitalWW.
'00 Jeep Wrangler - planning stage
What can BROWN do for you?
b_nom is offline   Reply With Quote
Old 06-25-2004, 09:57 AM   #6
Yuriy's Avatar
Don't worry, I'm fairly familiar with how diodes function
Well, I disected one of the adapters and made my little circuit - it works!
Old 06-25-2004, 12:07 PM   #7
binary.h4x's Avatar
actually why you cannot use a LED is because of is low reverse voltage rating.
binary.h4x is offline   Reply With Quote
If computer hangs, and constant current draw power issues Nic Power Supplies 0 06-14-2004 11:36 PM
Suggestions for current for a USB relay controller... Zac General Hardware Discussion 2 05-28-2004 12:52 AM
EPIA Standby Current? Jamez_Warner General Hardware Discussion 11 03-03-2004 11:15 AM
Using a deep cycle battery? nullity Power Supplies 11 02-08-2004 08:42 PM
testing for current and AT / ATX apparatus Power Supplies 3 12-15-2001 09:58 PM
