Go Back   MP3Car.com > Mp3Car Technical > General MP3Car Discussion
Old 08-16-2004, 02:51 AM   #1
cheerio's Avatar
Angry Car voltage problems
I have been having transmission problems with my car, and i got it 'fixed'. But now my check engine light is back on, and i took it back and they said its fine, the transmission problems now is a low voltage problem, easily fixable. I got a 2nd opion on this, so i believe it for now. Right now i have a xplod 600 watt 4 channel amp, pioneer head unit 52watts(but not in use), and a 300 watt alpine amp for my 2 12s". I was thinking abotu getting another battery and wireing them together, but i dont have the room under the hood for this. Would a high current output altinator be a better option? What do yall reccommend?
cheerio is offline   Reply With Quote
Advertisement Sponsored links
Old 08-16-2004, 03:49 AM   #2
l9nux's Avatar
Thumbs up
It's always a good idea to get a high current alternator, and depending on your car, you may be able to find a second hand one out of a diesel, or larger engine car. If you don't have room to add a second battery then a good battery such as the Optima (www.optimabatteries.com) will be an excellent replacement for the existing one.
-= I took the red pill =-
l9nux is offline   Reply With Quote
Old 08-16-2004, 08:01 AM   #3
Getting a bigger alternator could be quite expensive. If you have the cash why not.
But I would suggest making a tank circuit with an extra battery in your trunk just for your amps. Just do a on the forums for "tank battery" or "tank circuit" (without the quotes). The optima battery is excellent for the tank circuit because it's a gel battery and it's much better then a regualr acid battery.
I have the same issue, I have 2 AMPS powering 2-10", 2 6X9's, 2-4" and 2 tweets. And I'm thinking of doing the tank circuit for my amps.
Hope this helps.
VWMAN
"Live Long And Prosper"
car: VW Cabriolet '90
puter: M10000(toasted), Lilliput, CarNetix
status: In Progress
VWMAN is offline   Reply With Quote
For Sale for all you aussies. Complete mp3 car pc Holden__V8 Classified Archive 20 04-09-2005 05:30 AM
ITPS problems numberone Power Supplies 8 10-29-2004 04:07 AM
Epia M10000 + PW70a + car startup SuperSonic Power Supplies 6 11-27-2003 02:21 PM
Car Stereo Installation Video's for Sale johnram Classified Archive 2 09-05-2002 10:27 PM
