The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General MP3Car Discussion
Thread Tools Display Modes
Old 09-24-2004, 04:15 PM   #1
My Photos: (0)
USB harddrive disappeared
I just did a complete disk copy to backup the harddrive i use in my carputer. The image went fine and then i changed some of the drive letters on the backup harddrive that is always gonna be in my main computer.
After i changed the drive letters i still can't get the original drive to show up in windows. I'm trying to hookup the original via a IDE->USB interface adapter. I'm not positive whether i had it hooked up when i changed the drive letters or not. It's possible that changing the drive letters didn't have anything to do with it... but it worked 10 minutes before i changed the drive letters.
I have tried changing the drive letters back to what i think they used to be. Removing the backup harddrive and restarting with just the original and it still doesn't show up.
None of my harddrives are hidden. The disk doesn't show up in disk management (winxp). However, when i connect the harddrive (via usb) it detects the maxtor harddrive and mass storage device.
I have also tried hooking the harddrive up to a different computer via the usb connection and it doesn't detect them either.
What kind of diagnostic tools are there for such a problem?
Thanks in Advance,
~blake
http://www.blakerobertson.com
blak3r is offline   Reply With Quote
Sponsored Links
Old 09-24-2004, 04:21 PM   #2
Super Moderator
xBrady's CarPC Specs
xBrady's Avatar
Vehicle: 1999/Volvo/S80
My Photos: (1)
Just a thought, I had a maxtor that wouldn't show up either and the only way I could get it to show up was to install the drivers that came with it. Was awhile back and I'm not sure it would do anything since you did have it working... Don't know, something to try though. You could also try doing a system restore.
Installed.
-GPSSecure- - GPS Tracking
xBrady is offline   Reply With Quote
Old 09-24-2004, 04:26 PM   #3
My Photos: (0)
when i first put in the drive or try to go to disk management with the drive connected... the harddrive light comes on and it takes a long time.
All signs are pointing towards hardware failure but i thought i'd ask cause it seems pretty coincidental.
~blake
Old 10-01-2004, 03:31 PM   #4
SnyperBob's Avatar
Vehicle: 83 Hurst/Olds, 87 Grand National GNX
My Photos: (2)
It's a simple thing, but just try accessing your drive directly, especially if you know the previous drive letter.
So if your drive was the F drive, plug it in...
go to start->run and then type \\f:\
or type f:\ in explorer.
give it a try. Sometimes drive letters get lost on USB drives. This is a common issue on IBM machines with those USB flash drives.
SnyperBob is offline   Reply With Quote
Old 04-19-2005, 03:56 AM   #5
Fox_Mulder's CarPC Specs
Fox_Mulder's Avatar
Vehicle: 2004 MR2 Spyder TTR
My Photos: (49)
It is happening to me although I think it is due to hdd failure, Plug in the drive, takes forever to be recognised, the hdd light just stays on for a long time - but eventually goes off. Seeking data on the drive takes AGES! however the mp3's on the drive still seem to play fine off the drive without any lag or skipping. Scandisk can never complete a thorough scan on the drive it just locks up. Through MS-DOS Scandisk about 100 Bad sectors popup. Ah well it's been a good disk and it is probably on the way out.
Fox Mulder
2001 Toyota Avalon Vxi
Toshiba TE2000 Laptop 1Ghz BU-353 Black Xenarc 700TSV HD & Analogue TV FM DVD/CDRW Car2PC Adaptor
2004 Toyota MR2
Intel Dual Core 2.0Ghz 1Gb DDR2 160GB SATA2 M4ATX Lilliput 7" TS BU353
Fox_Mulder is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Problem with ITPS / hibernation and External USB HD veetid Power Supplies 5 01-02-2006 08:35 PM
possible? booting off external USB Harddrive. on mini itx nehemiah chicochu Newbie 10 12-20-2004 12:15 PM
laptop with usb harddrive mike86ttype General Hardware Discussion 3 05-22-2004 12:19 PM
USB Ext. Harddrive to PDA Hyp3rion General Hardware Discussion 3 04-02-2004 04:24 AM
Can I use a USB 2.0 harddrive enclosure with a USB 1.1 compliant motherboard? nxt125 General Hardware Discussion 7 09-01-2002 09:25 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
