Go Back   MP3Car.com > Mp3Car Technical > General MP3Car Discussion
Old 10-18-2004, 07:55 PM   #1
Regular PC Question
Hey guys - seeing if i could get some help with my desktop (non-car PC).
So here were my desktop specs
Intel P3 1.0 GHz
512 MB PC133 SDRAM
ATI 9600 PRO
SB Audigy 2
Linksys 802.11g PCI card
Maxtor Diamondmax Plus 40 GB HDD
Sony 12x CD-Burner
Toshiba 4x DVD-ROM
running win2000
i've had this configuration for about a year, with no problems. I left for work one day and my computer was on, and when i came back it was off and would not power on again. I tested the power supply, and it seemed to be dead, so I replaced it. When I replaced it, the LEDs on the mobo came on, and all of the fans spun, but the system didn't boot. Further I don't even think it POSTed (didn't hear the beep). Just in case the video card was toast somehow, I tried an old ATI Rage Pro card i had and still the same result.
edit: no signal to my monitor at any point during any of the above or below testing
So I bought a new PSU (Antec Trueblue 480), new mobo (intel mobo, 875 chipset, socket 478) and 3.2 Ghz P4 chip with 1 gb PC3200 ram. hooked that all up, popped in my ATI 9600 Pro, and still the same result as the old system. Tried the old Rage Pro and still no go.
I'm totally confused here. I've built and rebuilt a number of systems, but haven't come across anything like this.
any ideas?
VIA EPIA 533 MHz
256 MB RAM
7" Lilliput VGA Touchscreen
20 gig HD
Media Engine 2.1.4
GPS - Earthmate/SA2004
802.11b Connectivity
Nav_Attack is offline   Reply With Quote
Old 10-18-2004, 07:58 PM   #2
n00b 4 life
mp3oplecarrier's Avatar
What was the PSU that you replaced with, ie what power rating and did it have an extra P4 power connector?
New Car
New Car computer will follow........
(Gazes at pile of components)
mp3oplecarrier is offline   Reply With Quote
Old 10-18-2004, 08:06 PM   #3
grepzen's Avatar
i know this is silly.. but do you have (have you checked) pwer good at the wall socket?
•Micke
grepzen is offline   Reply With Quote
Old 10-18-2004, 08:16 PM   #4
hehe, yeah i did check the wall. thanks though.
the new PSU is an antec trueblue 480 watt psu, and it does have the extra P4 power connector.
VIA EPIA 533 MHz
256 MB RAM
20 gig HD
Media Engine 2.1.4
Old 10-18-2004, 08:22 PM   #5
binary.h4x's Avatar
check the 220/120 VAC switch on the back of the PSU
binary.h4x is offline   Reply With Quote
Old 10-18-2004, 09:24 PM   #6
yeah its at 120.
no luck there
VIA EPIA 533 MHz
256 MB RAM
20 gig HD
Media Engine 2.1.4
Old 10-18-2004, 09:52 PM   #7
Was your first system overclocked? Did you lock the AGP speed? Possible both vid cards have been damaged? When you turn on the computer did you listen to the beeps? They are coded and can help you determine what is wrong with your system. Let me look around for the beep code thing.
justICE is offline   Reply With Quote
Old 10-18-2004, 09:54 PM   #8
This link covers some of the popular bios' (saw phoenix and award).
Old 10-18-2004, 10:03 PM   #9
MySQL Error
jcdillin's Avatar
Dont want to jump to conclusions but I just had the same problem with a customer, the power supply blew and took the motherboard with it, but it didnt damage the CPU just the board.
肚子笑痛了
S60 Install
jcdillin is offline   Reply With Quote
Old 10-18-2004, 10:29 PM   #10
yeah the power supply blowing and taking the mobo with it is my best guess.
im hoping all the cards/drives still work.
it is possible that both vid cards are damaged but it seems unlikely.
its not beeping at all (when the system blew).
i can't hear the beeping on the new mobo because i have to alter the pc speaker plug.
not overclocked on the original p3. i dont kknow what locking agp means but it was operating at 4x.
VIA EPIA 533 MHz
256 MB RAM
20 gig HD
Media Engine 2.1.4
Old 10-19-2004, 10:35 AM   #11
Seth's Avatar
Since you now have a practically new system the problem might originate from a component common to the previous system. A burned HDD controller board for example can cause a system to not function.
One other possibillity is a short circiut between the new mobo and the case (the mobo is touching the case and grounds through it).
In any case I'd try to disconnect anything and try to power only the mobo/proc/gfx card outside of the case. And do a CMOS reset to the new mobo just in case...
Good luck!!
Seth is offline   Reply With Quote
Old 10-19-2004, 01:33 PM   #12
n00b 4 life
If the PSU took out the old graphics card and the new motherboard has an 8x AGP slot your old ATI may need a higher voltage..
New Car
Old 10-19-2004, 01:43 PM   #13
i have had exact problem, it was memory for me.
ecaandrew is offline   Reply With Quote
Old 10-19-2004, 09:03 PM   #14
well i have new memory.
i think the new mobo was DOA. i'm rma-ing it. hopefully when the new one comes in it'll work like magic. i'll try it outside the case first.
VIA EPIA 533 MHz
256 MB RAM
20 gig HD
Media Engine 2.1.4
silly question about pc lcd wires switch? icet General Hardware Discussion 0 06-17-2004 09:57 AM
Big noob question...can regular desktops work? Boofer97rs Newbie 8 06-09-2004 12:37 AM
DVD drive question Pokey Newbie 3 05-11-2004 05:26 PM
car pc, speakers question icet General Hardware Discussion 0 02-27-2004 02:42 PM
dumb question. how do you turn on the pc? Heedunk General MP3Car Discussion 24 04-03-2001 01:49 AM
