Quote: Originally Posted by
aec merlin
I bet you made new files in mspaint (or you selected "Copy" from ResHacker). The best way to modify the logos is to export the bitmaps from reshacker then edit them, which will preserve the depth and size of the bitmap.
I had the same problem as you (blank screen), then I realized that my new edited bitmaps had a depth of 24 bits, whereas the original ones were 4 bits (16 colors). After I corrected this, my new logos worked perfectly.
Well I exported the original file out and edit using PhotoShop. Then I reimport it back using reshaker.
But I'm not sure if it retains the depths (in this case, shallowness?
), but I did save it in 4 bits.
Maybe I should recheck later when I have time.
Thanks for the headsup, mate!
