Go Back   MP3Car.com > Mp3Car Technical > General MP3Car Discussion
Old 11-06-2004, 09:22 PM   #1
EBFoxbat's Avatar
LED Fan
Has anyone EVER seen an LED fan that can have the LEDs turned off and leave the fan on? It's driving me ape-****. I don't want to buy a fan that uses both 12v & 5v and have to add my own switch into the molex plug if I dont have to.
I'm looking to light the interior of my case but be able to kill the lights and keep the cooling.
Am I going to end up making my own fan bus?
'04 Canyon 4x4 pickup
[---PC on hold----working on external fiberglass "tool" box---]
EBFoxbat is offline   Reply With Quote
Old 11-06-2004, 09:43 PM   #2
Prolly you will if you want the fan's leds to turn off. Perhaps a different fan (the led fans are rather noisy in comparison to a good fan) and a CCFL or that flexible light strip stuff if you can't spare the space. I guarantee you'll get better illumination and a quieter carputer.
msb5150 is offline   Reply With Quote
Old 11-06-2004, 10:11 PM   #3
line your box with plastic mirror will also help with illumination
CPUFX is offline   Reply With Quote
Old 11-06-2004, 10:24 PM   #4
Zac
Same as my problem....I'm just too lazy to do anything about it. I figure you could make a switch to decide between 12v and 5v and with 5v the fan's LEDs wouldn't have enough power to light after the resistor, but the fan could still move at a slower speed. You could also make the voltage completely adjustable.......or buy a fan controller from like newegg or something. I think I'll stick with my large piece of cardboard for when I really don't want my case window lighting up the room tho. :P
Zac is offline   Reply With Quote
Old 11-07-2004, 09:28 AM   #5
EBFoxbat's Avatar
Most case fans (80mm and up) don't run at 5v. Some run but wont start. I won't lie, this is for my watercooled home rig. I'll end up making a fanbus. Center off toggles will give me this +12|off|+7 (you all know the 7v trick right?) 80mm fans run silent at 7v. I'm also entertaining the thought of making an LED strip. CCFL need inverters. Inverters are hard to hid inside a case. I'm anal about my case tidy ness. Today's project is to tidy up the cables under my desk....
That's still too messy!
Old 11-11-2004, 04:46 AM   #6
BassBinDevil's Avatar
You really need to take that case down to the platers and have it electropolished then gold plated. Then the computer will run much faster because the gold plating will make for a better high-frequency ground plane due to skin effect. OK; it won't, but how many people will know that?
BassBinDevil is offline   Reply With Quote
Do you need a very compact graphic fan controller? more mods LCD/Display 15 09-24-2004 07:17 AM
blinking power LED tunnel vision General Hardware Discussion 14 09-21-2004 01:45 AM
Case fan modified. Safe? cafn8 Off Topic 7 03-18-2004 11:57 AM
LCD to LED or LED meters. silvertoy LCD/Display 3 02-18-2003 12:07 AM
Reset / HDD activity LED JohnB1182 General Hardware Discussion 6 07-10-2002 03:48 PM
