08-10-2001, 11:42 AM
#31
Quote:
Originally posted by bgoodman:
<STRONG>Dos 7 w/MPXPlay Pentium 100 / 32mb
10 seconds boot time
 </STRONG>
I think I have the fastest boot time :P
08-10-2001, 01:13 PM
#32
Raw Wave
<STRONG>
I think I have the fastest boot time :P</STRONG>
What mobo are you running to get such fast boot times? My mobo's post takes more than 20 seconds, after that, the bit I have control of only takes 2-3 seconds.
Rob
6yr old first install died 20/8/2005 as result of bad bios flash.
New system : 6x5x2" contains 1GHz C3 PCM9373, ISR based PSU, 8Gb flash DOM, 98Lite, DirectShow based frontend.
GPS : Rikaline 6010.
Display : LTM08C351 + LVDS receiver.
08-10-2001, 09:28 PM
#33
Village Idiot
Umm...
A really old one..
That wasn't much help huh??
08-10-2001, 10:13 PM
#34
Quote:
Originally posted by Rob Withey:
<STRONG>
Rob</STRONG>
Dell Optiplex 5100 bought the system at a local shop for $30
08-31-2001, 01:21 AM
#35
Well for the people that are using older mobos, you might go into the Bios settings and turn off memory check, this is a feature that runs through the memory every time to check for any bad modules. So when this is not going, your pretty much onto loading the cdrom and HD, and off to windoze. I only say this because I worked on an old system the other month, and every time I restarted to test changes, it would take for ever counting mem and I got lazy qith the ESC key, so I turned it off. Not really any harm done, unless you have a bad mem stick, then the mobo just won't tell you, and youll find out later when loading, cant write...bla bla BLUE, and then you know to start testing. But thats all.
Later
ps. hey Charles...1 sec my *** lol
Subject open, Subject closed.
08-31-2001, 02:35 AM
#36
Village Idiot
18seconds, from power on until music.. DOS!!!!!!!!!!!!
08-31-2001, 02:44 AM
#37
21 Sec to boot And have Music!
Windows ME Full.
And Boot to CobraIII
08-31-2001, 04:28 AM
#38
10 seconds from the time I hit the power button till windows 98 is running. See setup below. Probably helps that the hard drive is totally empty hey?
AMD Duron 750, 128m RAM, 10gig WD, 12.1" TFT screen, SB Live! 5.1, custom plexiglass case
TalonTemple.com
08-31-2001, 07:20 AM
#39
Registered User
I had my system running in 19sec from cold boot.. (this was actually to see if all was working properly)
Now everything.. (and I really mean everything) is lying apart, and have to make a decent case and a decent lcd-cable.. (tried 2 times already.. both worked, but i wasn't satisfied. )
Greetz...
BTW..
Which soundcard would sound better. ? the 64bit-ISA or the 128bit-PCI
The 64bit has an extra control panel to adjust bass & treble, which I haven't found on the 128-PCI card
G.
Raas - The Netherlands
ME: VIA epia m10000, lilliput 7', opus 150w, 80gb<br>
GF: IBM Thinkpad 380, ext. 3.5 80gb, 40x4, PB-IR
08-31-2001, 07:30 PM
#40
Quote:
Originally posted by Raas:
[QB]Which soundcard would sound better. ? the 64bit-ISA or the 128bit-PCI
The 64bit has an extra control panel to adjust bass & treble, which I haven't found on the 128-PCI card[QB]
if your using winamp, make usage of the EQ..... I am using a Vibra 128 since they are easy to find/nice and cheap.
Project - GAME OVER :(
| Thread Tools |
| Display Modes |
Linear Mode
