Go Back   MP3Car.com > Mp3Car Technical > General MP3Car Discussion
Old 10-12-2001, 11:09 PM   #1
ifnh573
Question custom dash making....
Is making custom dash with bondo body filter any good? I have a 98' accord and there is huge space under the head unit on the dash. I am making an enclosure where the 8.6" touch LCD will be put. I made the frame with cardboard and already applied 1-layer of body filter.(Sun died out early today......the body filter activates by the Sun.....)
My question is......does it last long??(does it stand hot, cold temp.???)
What kind of paint should I use?? I heard that Sem's plastic paint spray works great on plastics, but would it work on this bondo-stuff???
I haven't done any interior stuff before.....can anyone help me on this??
Is there any better, easy way of making the frame(mold) besides cardboard?? Fiberglass is out of option......it makes too much smell....I am primarily working indoor.
ifnh573 is offline   Reply With Quote
Advertisement Sponsored links
Old 10-13-2001, 01:39 AM   #2
mp3ford
Post
As a medium by itself, body-filler is not good for building structural elements. Body filler is simply a form of fiberglass, fine chopped, in a resin slurry. Like fiberglass, it uses a catalyst to harden. So in terms of smell, it's not all that different from fiberglassing. The problem with using body filler, is that the fiberglass chop has extremely short fibers, which does not contribute to strong and resilient construction. The medium is also denser, which translates to a much heavier weight overall.
Making a cardboard plug just slightly smaller than your intended form is one way. The other way, that i've experimented with, with my latest project, is a 3 step process involving making a male plug in exact dimensions of the final product out of structural foam, then making a plaster of paris female mold using the male plug. The plaster of paris mold is then fiberglassed with 2-3 layers of fiberglass, and then the plaster of paris mold is broken up from around the raw finished product. As you can guess, you get one chance at getting it right. It's a one use, destructive process. This is not a cheap process - i spent about $100.00 alone on molding and materials for building the raw final product.
It can be also messy as hell.
My suggestion - fiberglass, but to cut down on the odour, remove the curing fiberglass to the trunk of your car or whatever, and clean up real well, this will cut down on the indoor smell. I do my fiberglassing in the garage, so i know the stink - it permeates inside the house.
i'm going to try enamel paint, once my project is done, i'm getting closer to finished, just a long process to get the final project sanded, smoothed down and ready to paint.
My fiberglassed console, about two months ago, just after removal from the plaster of paris mold and rough trim down. Progress on sand down and final finish is considerably closer to done, than this old photo indicates.
mp3ford is offline   Reply With Quote
'93 Opel Vectra A - Custom Dash & Custom Case zvi Show off your project 14 10-18-2005 08:36 AM
Does this Custom Dash Pass the the MP3Car test? antimatter Fabrication 20 12-22-2004 02:34 PM
2003 G35 Sedan Custom Dash And Computer Izik Show off your project 57 08-22-2004 01:45 AM
custom dash? Jamez_Warner General Hardware Discussion 1 06-14-2003 06:53 PM
Plastic moldings for custom dash mykolJay General Hardware Discussion 1 06-26-2000 01:06 AM
