^^ To add to the above post, here are my present mobo specs
Features & Specifications:
CPU: Includes embedded VIA C3 1GHz processor
Chipset: VIA CLE133/VT8231
System Memory: 2 PC 133 DIMM socket, Up to 1GB memory size
Form Factor: Mini-ITX
IDE: 1 x ATA DMA 100/66
Slots: 1 x PCI
Onboard LAN: VIA VT6103 10/100 Base-T Ethernet PHY
Onboard Audio: VIA VT1612 2 channel AC'97
Onboard I/O Connectors: 1 USB connectors for 2 additional USB 1.1 ports. CD Audio-in connector. SIR connector. CIR connector. Wake-on-LAN, Wake-on-Ring. CPU/Sys FAN/Fan. System intrusion connector.
Back Panel I/O: 1 PS2 mouse port. 1 PS2 keyboard port. 1 Parallel. 1 RJ-45 LAN port. 1 Serial port. 2 USB 1.1 ports. 1 VGA port. 3 Audio jacks: line-out, line-in and mic-in.
Looks like a new USB card and amp, or a new mobo may be in order.
