Go Back   MP3Car.com > Mp3Car Technical > General MP3Car Discussion
Old 02-01-2005, 11:27 AM   #1
EBFoxbat's Avatar
Startup is too fast!!!
I have a few programs that run in my tray on startup. Nothing to intensive just so programs I like to have run. One of them requires a live internet connection which I have with cable. However, the program tries to connect to the internet apparently before my computer has gotten its IP from my router. Thus I get DNS errors and stuff.
Is there a way to delay programs that run on startup? I only need it to delay 2 or 3 seconds. Any ideas? Would moving it into the startup folder do any good (right now it's just enable in msconfig)?
'04 Canyon 4x4 pickup
[---PC on hold----working on external fiberglass "tool" box---]
EBFoxbat is offline   Reply With Quote
Old 02-01-2005, 11:30 AM   #2
EBFoxbat's Avatar
BTW google only offers programs that do this... I was hoping to do it with a registry hack or something.
Old 02-01-2005, 12:39 PM   #3
delete its registry startup entry and put it in the start menu starup folder... that may work
thecommiser is offline   Reply With Quote
Old 02-01-2005, 01:20 PM   #4
EBFoxbat's Avatar
Didn't work.
Old 02-01-2005, 01:29 PM   #5
There's a way to run a batch file (*.bat), and in that batch file, delay for a little bit, and then run a program.
Sorry I don't remember the commands off of the top of my head, but it's not very hard.
wizawuza is offline   Reply With Quote
Old 02-01-2005, 01:29 PM   #6
Ill1's Avatar
Use AutoHotkey, www.autohotkey.com , to create an exe that waits for a said amount of time and then runs whatever program you want. Off the top of my head the script would be something of this nature:
Sleep, 3000 ;wait 3 second
Run, FULL_PATH_TO_PROGRAM_YOU_WANT_TO_RUN
Compile the script and place it in your startup folder. This probably isn't what you were looking for, but it is a solution.
________________
______ILL.1______
Ill1 is offline   Reply With Quote
Old 02-01-2005, 02:32 PM   #7
EBFoxbat's Avatar
I made a batch file and tossed that in the startup folder
Code:
@ECHO OFF ECHO Delaying gNotify start up. Please wait. SLEEP 1 CLS ECHO Delaying gNotify start up. Please wait.. SLEEP 1 CLS ECHO Delaying gNotify start up. Please wait... SLEEP 1 CLS ECHO Delaying gNotify start up. Please wait. SLEEP 1 CLS ECHO Delaying gNotify start up. Please wait... START "gNotify" c:\gmail\gnotify.exe
I wish there was a way to trick the file into thinking that I pressed the enter key.
Old 02-01-2005, 03:50 PM   #8
EBFoxbat's Avatar
The SLEEP command won't work unless you download sleep.exe from microsoft.
Old 02-01-2005, 03:55 PM   #9
MySQL Error
jcdillin's Avatar
why do you need to press the enter key?
肚子笑痛了
S60 Install
jcdillin is offline   Reply With Quote
Old 02-01-2005, 04:06 PM   #10
MySQL Error
jcdillin's Avatar
Nevermind, I see your problem, if you make a shortcut to the gmail.exe file and keep in the same folder as the exe and change your batch file to the below it should make the dos window dissapear
Code:
@ECHO OFF ECHO Delaying gNotify start up. Please wait. SLEEP 1 CLS ECHO Delaying gNotify start up. Please wait.. SLEEP 1 CLS ECHO Delaying gNotify start up. Please wait... SLEEP 1 CLS ECHO Delaying gNotify start up. Please wait. SLEEP 1 CLS ECHO Delaying gNotify start up. Please wait... c:\gmail\gnotify.lnk
肚子笑痛了
S60 Install
Old 02-01-2005, 04:06 PM   #11
MySQL Error
MatrixPC's Avatar
Ask the 9 finger monkeys to help you out with a little VB proggy. Shouldn't be that hard (I can do it but will take me a while) for a pro like him.
BTW, but the program in the start up folder will run, but may have problem when returnning from hibernate.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 02-01-2005, 04:27 PM   #12
Try using this instead of your regular dos box...
http://www.commandline.co.uk/cmdow/
this option is the one i was talking about:
/HID Hides the specified window. Although a hidden window will not be shown on the taskbar, it will still run and may be unhidden later.
Herb_Davis_Y2K is offline   Reply With Quote
Old 02-02-2005, 04:57 PM   #13
EBFoxbat's Avatar
The DOS window does dissappear. When gNotify does establish a connection it promps me for a username and password, which are stored by windows. I just have to click OK or hit ENTER if its the active window. I was wishing I could make the batch file hit enter
Old 02-03-2005, 10:09 AM   #14
It's not really that small...No, seriously.
judoGTI's Avatar
Could you hardcode your IP on your computer to what the router will provide for you to make it more instant?
'02 GTI
[Routis '04] [Opus 90W] [160GB Maxtor HD]
[Lilliput 7" TS] [VIA M10000] [XMPCR]
[512MB RAM] [Custom housing]
[Deluo GPS Mouse] [E-MU 0404 Soundcard]
Progress Meter: [==============|] 99.9%
judoGTI is offline   Reply With Quote
Old 02-03-2005, 10:32 AM   #15
Nobias's Avatar
Dont know if this will help but i was bored. It's an app to launch a program after a specified amount of time. Info in the INI.
Status: 40%
Car: 2006 Scion tC (Buying)
CPU: AOpen Pandora/1.5 Cel M/1GB DDR2/Ipod Vid
Screen: Lilliput 7"
Power: Carnetix 1900
GPS: Deluo GPS
Software: nLiteXP, RR, IG, PhoCo
XM: XM Direct
http://www.chrispuckett.com/mp3car/
Nobias is offline   Reply With Quote
Music track fast forward bug Bootbox CF Bug Reports 4 12-06-2004 11:22 AM
Laptop Startup Solution - Opinion Fox_Mulder General Hardware Discussion 0 11-20-2004 05:33 AM
Co-Pilot 7 On-Screen Keyboard -- bad response if too fast? Sensor GPS 3 09-28-2004 02:13 AM
usb fast enough? ShinkunoNamida General Hardware Discussion 5 06-02-2002 02:52 AM
Fast and the Furious (Arby please read) hornet Off Topic 15 03-17-2002 04:26 PM
