The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General MP3Car Discussion
Thread Tools Display Modes
Old 06-05-2005, 04:36 AM   #1
My Photos: (0)
Troubleshooters! Computer turns off randomly and wont turn on, need help
hey guys.. so i have a pretty weird problem. i am running a mini itx mobo m1000 with an itps. My computer will randomly turn off while its operating, and it wont turn back on again. The standby usb power doesnt stay on either. meaning, normally i have a usb hub plugged into the computer, and whenever there is power to the computer the LED on the hub lights up, even if the computer is off . I checked the output on the itps, which feeds into the computer, and there is power there. But then randomly, when i am driving around, randomly the light on my usb hub will light up, signalling that the computer has power. And then i can push the power switch and the computer will boot up. So what i want to know is: is this a motherboard issue, or something else? is it possible that my harddrive has been corrupted somehow, and when it gets stuck or hits a bad sector, it crashes the entire computer? but that wouldnt explain why i lose power everywhere. Please help. Thanks in advance guys.
phatbimmer is offline   Reply With Quote
Sponsored Links
Old 06-05-2005, 05:05 AM   #2
Para Laura
thanatos106's CarPC Specs
thanatos106's Avatar
Vehicle: Xterra SE supercharged
My Photos: (0)
Lots of people here had bad experince with Itp http://www.mp3car.com/vbulletin/show...highlight=itps so you may want to double ckeck that.
Other problem could be heat.... So maybe with a little more inpu from you we can help you better...
1.when you checked the itps what number are you geting??
2.there is any source of heat dissipation in the car pc i.e thru fans or a/c
3.this only happen when you are driving or when the engine is off also???
thanatos106 is offline   Reply With Quote
Old 06-05-2005, 11:38 AM   #3
Super Duper Moderator
Bugbyte's CarPC Specs
Bugbyte's Avatar
Vehicle: 2001 VW Beetle
My Photos: (14)
Your ITPS could be overheating. I had to put a fan on mine when I used one and that helped a lot.
You realize, of course, that the ITPS is a piece of dung, right? Replace it with a Carnetix 1260/80 and banish your power issues.
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Old 06-05-2005, 03:47 PM   #4
My Photos: (0)
1. i checked the itps when the car was off and i got around 11.4V and when the car was on i think i got around 12.6 or something, not exatcly sure.
2. i have installed 2 small chassis fans on the outside of computer, mounted to the roof of my trunk to help with heat dissipation and air flow.
3. when this happens, it is regardless of whether the engine is on or off.
--> i believe that it might have something to do with the mobo itself. i realize that the itps is not the greatest part ever, but it seemed to be doing the job for me. i think i might change to an opus or carnetix sometime soon.
Anyody know if it could be related to some motherboard issue, such as a blown cap? is there any way to test these things?
Old 06-05-2005, 05:09 PM   #5
Bugbyte's Avatar
My Photos: (14)
It's not whether the car is on or not, it's whether the ITPS is being used or not. How many watts does your system draw? If it's more than 60, you're drawing too much on your ITPS.
Sponsored Links
vB code is On
Trackbacks are Off
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
