Go Back   MP3Car.com > Mp3Car Technical > General MP3Car Discussion
Old 01-30-2002, 08:15 AM   #1
Registered User
Question Soundcard Equalizer
Hi
Iīve just a short question:
Does anybody know if thereīs a 6-channel soundcard with level-adjustment and equalizer-function for each of the 6 channels ? As far as I know the creative 5.1 or Audigy Player donīt have these features.
It would save a lot of money cause my amp doesnīt have any sound-adjustment devices and I donīt want do buy another analog 6-channel equalizer.
Thanks in advance
VW GOLF III GT ī93
[Xenarc 700TS] [Epia M10000]
[256Mb RAM] [20Gb IBM 2,5" HD] [WIN XP Pro] [Bicker PSU] [Soundblaster Extigy] [######### -] 90%
Golf_MPIII is offline   Reply With Quote
Advertisement Sponsored links
Old 01-31-2002, 08:05 AM   #2
Registered User
Unhappy
Iīm just wondering if nobody canīt or wants to answer my question.
Iīve used the search option before and I can understand why you donīt reply to questions that have been answered for a hundred times but none of the shown topics dealt with this question. And youīve ansered more silly or nonsense questions than this one I think.
So whatīs up with you ?
VW GOLF III GT ī93
Old 01-31-2002, 09:49 AM   #3
Registered User
Post
I'll bite....
Wouldn't the equalization for each channel come in some form of software that controls the 5.1 soundcard. Have you looked for software, plugins, drivers, etc. for these different soundcards that may do what you want the card to do.
CALIBOY is offline   Reply With Quote
Old 01-31-2002, 10:09 AM   #4
jboy's Avatar
Post
I remember seeing this done with an external sound card from event electronics, i forget the model # but it had tons of IO I think it was 8 analog outputs that could be controled seperatly, this is going back afew years but it may be worth looking into
If you come out talking sh1t don't try to turn around and wipe you azz.
jboy is offline   Reply With Quote
Old 01-31-2002, 07:24 PM   #5
Post
Do you have one amp driving your entire system? I am assuming this becuase of the 6 channel configuration. If it were my install, I would use an external crossover, unless there is a good one in the amp. In that case then I would enable the amp to work off a 2 channel input, or maybe four channel if you are setup front/rear instead of high/mid/low
KG6OQD
www.americansandassociation.org
AVGeek is offline   Reply With Quote
Old 02-01-2002, 02:33 PM   #6
Registered User
Post
The problem is that the amps (5-channel for front/rear& 2-channel bridged for sub) have highpass/lowpass but nothing else.
No further equalization.
An I just thought, that there would be a card with frequency controlling for each channel and some sort of delay option to delete time-errors. I did not want to run it in 2-channel-mode even though I could use e.g. Winamps Equalizer because 5.1 Digital would not work then.
But another question was if 6-channel cards are just playing on all six channels in D.D. 5.1 mode while watching DVD or even while using Winamp.
Iīm not sure, but i thought there was some option called "pseudo 5.1" to run all 6 channels with a simple stereo signal.
I think the easiest way is to buy a 6-channel analog equalizer for 300 bucks...
[ 02-01-2002: Message edited by: Golf_MPIII ]
VW GOLF III GT ī93
Old 02-01-2002, 06:29 PM   #7
PatO's Avatar
Post
I'll be writing up an AMP mod guide sometime soon. Basically, I bought a cheap amp from Best Buy, popped the sucker open and removed the daughter board containing the sound adjustment controls (gain, high-cut, low-cut, etc). Slapped the board into a homemade plexi box and wired the thing up with CAT5.
Beautiful amp controls sitting right next to my carputer keypad. I have never seen the insides of other amps, so I don't know how many others have small-ish daughter boards for the controls, though...
http://jeepmp3.home.comcast.net
CarPC Stolen. Starting over.
Ne1 recognize the avatar?
PatO is offline   Reply With Quote
