Go Back   MP3Car.com > Mp3Car Technical > General MP3Car Discussion
Old 11-24-2001, 03:41 PM   #1
peter3's Avatar
Post where can i find a lcd controller?
Hello just thinking of getting a 4" lcd (4lu4e ~$20,-).Now i'm looking for a lcd controller (cheap ) Is there someone who can tell me where to get them?
I maild earthlcd.com and they maild me back with this: it is only sold in a kit with the lcd sk-3001 for $149 . I know they where sold for ~$25,-. If anyone has a spare i'll be happe to make you an offer.
peter3
pwvanderveen@hotmial.com
or
peter.wendy@keyaccess.nl
PETER - THE NETHERLANDS - DEVENTER
sproggy 2.8,epia c3-800,20Gb 2.5", 5.6"lcd,touchscreen.
peter3 is offline   Reply With Quote
Advertisement Sponsored links
Old 11-24-2001, 08:22 PM   #2
Post
where did you get them for $25 and who makes the LCD, and how good is it??
you might want to check out flat-panel to see if they can help you, or check on eBay or just do a google search for the model number of it.
IN DEVELOPMENT -- '96 Mustang, lilliput with PII/450 laptop, custom DC-DC power supply, 60GB; Garmin GPS; 802.11g; compact keyboard, small graphical LCDs, OBDII.
Telek is offline   Reply With Quote
Old 11-25-2001, 01:33 AM   #3
peter3's Avatar
Post
Earthlcd.com has taken over flat-panel.com
As for the price from the controller i looked at this page: http://www.flat-panel.com/faq4lu4e.htm and at the bottum of the page u see what i mean.
peter3
Old 11-25-2001, 11:04 PM   #4
Registered User
spud42's Avatar
Question
i have the sharp manual for this lcd as i am about to use one. it will take EITHER rgb OR ntsc input. email me direct if you want a copy of the .pdf file...
timothy.hunter@compaq.com
NISSAN 180SX SR20DET 2lt TURBO 5 spd , gigabyte ga5ssm mobo,AMD k6 ii 450 Mhz,128 meg ram,4" sharp lcd,40 gig Hdd. IRMAN WinAmp ,TinyXP.ipaq4700 ,WM 6.1 ,4 Gig CF,TomTom 6,TCPMP edited 23/9/2008
spud42 is offline   Reply With Quote
Old 11-26-2001, 06:01 PM   #5
peter3's Avatar
Post
Spud42 thanks for the post
Just send you a mail
If there are some people outthere who have some info on the 4lu4e i'l be happy to heare from you
peter3
Old 11-26-2001, 07:07 PM   #6
g60
Post
I've got one of these screens comeing in the mail right now. Sounds like it's going to be a bit bigger project than I was expecting
spud42: I'm going to e-mail you too.
>\\MP3G60//<
g60 is offline   Reply With Quote
Old 12-01-2001, 01:11 AM   #7
g60
Post
Woot! Just got my screen, now I got to figure-out how to hook it up
Earth lcd has this schematic for the converter board http://earthlcd.com/cnt4lu4e.pdf .
The only thing I'm not famillar with is the IC(?-JP3). Is this something I can get from radioshack?
And the powersupply, is there somewhere I can buy that cheap? Easy to make?
Can't wait to get this going
>\\MP3G60//<
Old 12-01-2001, 07:35 PM   #8
peter3's Avatar
Post
Hello g60
jp3 is a connector/header 13x2
not a ic.
Let me know when it works.
peter3
Old 12-01-2001, 07:53 PM   #9
g60
Post
Ok, this header, is it just to connect the red, green, blue, and c-sync to ground?
I guess it's not really needed
I just need to find out what the values for the resitors and caps on the power supply are, and find some small ribbon cable.
>\\MP3G60//<
Old 12-02-2001, 01:00 PM   #10
peter3's Avatar
Post
This header is for connectin the lcd to the motherboard if it has a lcd controller on board.
Let me know if you find the values of the components.
peter3
Old 12-04-2001, 12:27 PM   #11
g60
Post
I wired my screen last night, I've just done a real basic version of Earths board.
Since i'm just going to use ntsc, I've igroned JP3 & JP4. Also I figured finding a tiny flat ribbon cable would be pretty impossible, so I removed(/broke ) the connector(JP5). The lcds circut board has an open hole for all pins, so I just carefully soldered some ide cables on.
I'm going at lunch to find a power supply, so hopefully tonight I'll have a picture
>\\MP3G60//<
Old 12-04-2001, 01:06 PM   #12
Registered User
mp3z24's Avatar
Post
actually, i just got one of those screens also, and when i inquired to earthlcd i got the same response. however, i decided to call them and i was prepared to argue my way into getting one, but the guy i talked to said that they sell them independent of the screen.
i talked to Al when i called them, and the price is $25.
~mike
Single Member of the "1000 Post and No MP3 Car" Club
PROJECT ON INDEFINATE HOLD... BOUGHT A HOUSE
2000 Cavalier Z24 [###-------] Only 30% Done ... Still
mp3z24 is offline   Reply With Quote
Old 12-05-2001, 01:05 PM   #13
g60
Post
No luck last night
I wired it like this.
I used a 8v voltage regulator hooked up to my computers 12v, no blown fuses on the lcd. Backlight works.
The only thing I'm not sure about is how I wired pots - 5v to middle, ground on one side, and output on other side. Correct?
>\\MP3G60//<
Old 12-05-2001, 04:47 PM   #14
peter3's Avatar
Post
hello g60
No you must put the 5Volt on one side the output in the middle and the ground on the other side. then it's the same as the drawing.
your drawing is oke to me.
hello mp3z24
thanks for the info when i get mine lcd in the mail (europe takes some time) i'll have a look like g60, if i can't find a way to let it work i've to order one controller.
peter3
Old 12-06-2001, 03:56 PM   #15
g60
Post
I think I've blown the 5v output
Tonight I'm going to try using the 5v from my computer.
>\\MP3G60//<
