09-01-2001, 03:44 AM
#1
IRMAN ..add another "eye"
would the IRMAn work ok if i solder another "eye" onto it so it has two ?
I wanted to have an extra one for the computer when I take it inside and the other mounted on the dash somewhere...
anyone tried this or have any suggestions?
09-01-2001, 09:49 AM
#2
I think it will work ok, aslong as the remote doesn't see them both at the same time.
Peter3
PETER - THE NETHERLANDS - DEVENTER
sproggy 2.8,epia c3-800,20Gb 2.5", 5.6"lcd,touchscreen.
09-01-2001, 01:00 PM
#3
i am requesting some samples...
I found a VERY interesting link about making an IRMAN /UIR device without a PIC to be used with Guirder only ( cost I think is $2)
check it out
http://www.cesko.host.sk/girderplugin.htm
09-02-2001, 06:37 AM
#4
I dont think that device would be very sensative compared to the irman. Tell us how you go with the two IRMan "eyes". I spose it could work....
if it doesnt you could always run two IRmans on twin com ports!
Project - GAME OVER :(
09-02-2001, 07:54 PM
#5
That $2 IR receiver will use more CPU than an IRMan because the IRMan uses a hardware decoder. The $2 one requires special software to decode the infrared and thus uses more CPU power. It won't be as compatible as the IRMan either (with software that is).
BoominVolvo
http://olymp3.mp3car.com
09-04-2001, 06:35 AM
#6
Yes, I have been doing this for almost 1 yr now. If you take a look at my box, you will see what i mean.
abcd-1
09-04-2001, 07:04 PM
#7
Hey Charles where did you get the other IR receiver (eye) I believe the part # is TSOP1736 made by Vishay. I can't find it...
09-04-2001, 07:22 PM
#8
Quote:
Originally posted by moahdib:
<STRONG>Hey Charles where did you get the other IR receiver (eye) I believe the part # is TSOP1736 made by Vishay. I can't find it...</STRONG>
there are a few equilivents to that part. I know that Sharp produce a variant that works....
09-04-2001, 10:12 PM
#9
The Dick Smith in Australia sells one for around AU$3.50 (~US$1.75) i think they do take international orders.
I'll check the part number and will post it here.
Here is they web site www.dse.com.au
Fosgate
System Comp V3 - In progress.
Low power MB with C7 CPU, DC-DC PSU, car ECU link, USB TV, GPS, 7" TFT, Wireless, Voice.
09-05-2001, 04:11 AM
#10
Village Idiot
Is the sensor the same as in VCRs and TVs?? I have a couple of them and am going to try one....
09-05-2001, 11:33 PM
#11
I have tried using a VCR sensor but it didnt work for me. I think they not sensetive enough and they use external amp.
But then again it might work with different sensors.
Fosgate
09-06-2001, 04:09 AM
#12
Village Idiot
The VCR sensor I have can be used to directely drive a LED...
09-06-2001, 04:21 AM
#13
Quote:
Originally posted by Fosgate:
<STRONG>I have tried using a VCR sensor but it didnt work for me. I think they not sensetive enough and they use external amp.
But then again it might work with different sensors.</STRONG>
yeah the one for the IRman has the filter circuit, etc, etc built onto it.... basically a IR sensor with a small IC stuck to the back of it.....
09-07-2001, 02:04 PM
#14
I got lucky and contacted a distributor for that same exact part and he is sending me 5 samples of the IRMAN eye =) (TSOP1736 by Vishay Telefunken)
yay!
09-07-2001, 10:12 PM
#15
Village Idiot
Are you sure thats the right part??? it works at 36kHz, you might need a different one...
| Thread Tools |
| Display Modes |
Linear Mode
