Go Back   MP3Car.com > Mp3Car Technical > General MP3Car Discussion
Old 10-03-2001, 01:42 AM   #1
Post 25 or 50 Watts Amp
Does anybosy know where I can get 25W or 50W amp?
Thank you
accord is offline   Reply With Quote
Advertisement Sponsored links
Old 10-03-2001, 01:44 AM   #2
Village Idiot
Post
Whats it for??
The car, house, what??
You could make one for the house for really cheaply.
SkinnyBoy is offline   Reply With Quote
Old 10-03-2001, 09:05 AM   #3
Retired Admin
Aaron Cake's Avatar
Exclamation
Moved to Commercial Hardware.
Aaron Cake is offline   Reply With Quote
Old 10-03-2001, 01:32 PM   #4
Post
I need it for car , I'm puting sound directly to speakers from a soundcard. I need small amp (25w or 50w) for center speaker and 2 bass shakers.
I don't mind make it , if there is kit.
I can put them together but I don't know how to design.
Old 10-03-2001, 09:10 PM   #5
Village Idiot
Post
If you are making it, you have more flexability, would you want 3 channels?? 1 for the center speaker and 2 for the bass shakers??
National has an amp IC that can deliver 170watts into a 4ohm load with +-28volts, You can also use it with +-12volts and get 60watts into a 4ohm load, but then you have the problem of getting + and - in the car..
For more info, go to nationals site, www.national.com , and search for LM4651 and LM4652, one of these devices is the amp, the other is a MOSFET chip.
Old 10-03-2001, 09:38 PM   #6
Post
dont make an amp....... buy a good quality name brand amp.... they have spent the time producing these things, so they know what they are doing!
Personal choice is clarion, kicker, pioneer....
Project - GAME OVER :(
magnetik is offline   Reply With Quote
Old 10-03-2001, 11:44 PM   #7
Post
I remember i got my Alpine 2x25 amp from an old Mercedes (early 80's model). Those cars used to come with Alpine stereo system as standard and it seems like they had seperate amp for the deck.
I used to run my 12's of it for a while (everybody though it was a cross over dox, Its bit biger then a cigarett box and the quality is great)
and now it gave it to friend of mine to run his 6x9 of it.
If you have a local car yard give that a try you might pick one up for few dollars.
Fosgate
System Comp V3 - In progress.
Low power MB with C7 CPU, DC-DC PSU, car ECU link, USB TV, GPS, 7" TFT, Wireless, Voice.
Fosgate is offline   Reply With Quote
Old 10-04-2001, 03:19 PM   #8
Post
I found some 25W Amps. which I can use for bass shakers, but should I do with center speaker.
I'm gonna get this center speaker
The power range is 2-15 Watts
and I don't think any mobile audio company makes amp that low.
any suggestion?
Old 10-04-2001, 10:36 PM   #9
Village Idiot
Post
How many ohms is the speaker??
That would make a diference as to what amp you could use..
Old 10-05-2001, 12:08 AM   #10
ppgt94's Avatar
Post
25/2 for bass?? How big are the woofers? 4"?
ppgt94 is offline   Reply With Quote
Old 10-05-2001, 09:51 PM   #11
Post
Well I don't know.
I's Panasonic EAB-CF2 center speaker.
only information I can find out this speaker is
* 3-1/4" speaker in compact enclosure
* frequency response 400-20,000 Hz
* power range 2-15 watts
* sensitivity 82 dB
from crutchfield.com.
Well it's not a woofer , it's bass shaker also known as bass kicker. It makes vibration under the seat so you can 'feel' the bass. by the way I have Rockford Fosgate 15" woofers in the trunk
Old 10-06-2001, 06:08 AM   #12
Village Idiot
Post
Quote:
Well I don't know.
Well, measure it..
If it were 4ohm, we, (you), would want an amp able to deliver 10watts with a +13volt supply, so, I will see what I can find..
Okay, I found this, but before you use it, I suggest you get the Thumbs Up from someone else, because they all doubt my electronics knowledge..
If it doesn't work, then try clicking here or copying and pasting the link below: http://www.geocities.com/bob_in_car_...123123.bmp.jpg
If you power the amp from 12volts, you can get 10watts into a 4ohm load, okay..
The amplifier IC is available from National, you SHOULD be able to get it as a free sample, and the rest of the components are easy to find..
[ 10-07-2001: Message edited by: SkinnyBoy ]
Old 10-09-2001, 07:21 PM   #13
Village Idiot
Post
I changed my mind, you can't use this circuit, there is more to it to use it, you could use "half" and get 5watts??
Old 10-10-2001, 02:52 PM   #14
Post
Keep in mind that as far as the bass shakers alone are concerened, they just vibrate (as opposed to "reproducing" good, clean sound) so you can get away with the dirtiest, cheapest amp you can get your hands on.
One of those old, cheap (5 bucks at a garage sale or pawn shop) 40-watt "power booster" amps will work just fine with these.
~m
PII 266, 512 MB RAM, 10 Gig, 36x CD-ROM, 16x DVD, DeLorme GPS, 5.6" LCD Screen, Dschmidt power controller, Keypower ATX DC-DC Supply, PowerAmp Macro controller, Dauphin mini-Kbd.
Sony Head Unit, Sony Unilink input selector, rear deck Kenwood 6x9's, stock door spkrs... All in my '96 Civic, of course :}
BC ROCKS!!!
dos4who? is offline   Reply With Quote
