Quote: Originally Posted by Fooch
Ok, cool thanks for that.
1.) what do I shield them with? and how far apart should they be? I am running both through the center console. I got maybe 1 foot between sides to run wires.
I've heard tales of shielding cables with aluminum foil. I have no idea whether that actually works.
Seperate them. Run them down seperate areas of teh vehicle, as far away from one another as possible.
Is that mroe work? You bet! nothing worthwhile is ever simple.
Quote:
2.)It is on a metal surface but not trying to look through one. It is going through plastic though(but it is covered in plastic so I wouldn't think that would matter), and has a clear view of the tinted window. I will try relocating it tomorrow and see if it helps.
If you relocate it and it picks up satellites with no problems, then you know the problem.
Quote:
3.)I will go pick one of those up. any recomendations of where to get the power invereter? I am looking for a 200 RMS and 400 PEAK inverter right? Or should I go 300/600? I don't have much to blow lol
What's the rating of your PC power supply?
Again, the rule of thumb is 150% of your PC's power supply AT LEAST. You do your own math.
