From my other post...
Setup is microatx msi mobo, 512mb ram, athlon mobile 2500 clocked at 1700mhz, opus 150, all usb devices run off of pci usb card which cuts +5vsb.
Quote:
Ok, I ended up plugging everything into the PCI usb card. It seems that when the computer goes into standby, all the devices shut off. I put a mulitmeter in line with the ground wire feeding the opus and cycled power. I turned the computer on, sent the computer into standby, and while in standby it was only drawing 1.5mA. While still plugged in, I turned the computer back on and it resumed from standby in <3 secs.
I plan to retest the overall current draw at the battery using a clamping style meter so I do not have to disconnect anything, but figured testing the 12v or gnd line feeding the opus would give me a good idea of how much more I was drawing than my stock setup without the computer.
We will see if the 1.5ma is true or not.. I would also like to see others for comparison.
I should note that I have been running it this way for a few weeks now, and no dead batteries. I have only left it sitting overnight, one instance maybe 16 hours. It started up just fine. This is with an optima red top btw.
Hope this helps.
