Go Back   MP3Car.com > Mp3Car Technical > General MP3Car Discussion
Old 09-18-2005, 11:26 PM   #1
TyBong's Avatar
Exclamation Ground noise in system
I've got an old receiver I have modified into a carPC, I currently am powering this system by a power inverter (might I add is a complete waste of energy). I threw this system in my 02 camry, jack everything in, works fine. the problem is when the car is on, I have alternator whine through the speakers. I have made previous generations of carPC's in my other vehicles and I have always stressed to myself "ground everything" (pretty much), and the typical way I solved alternator whine was to ground the audio signal before it goes to my alpine deck to the frame of the car, usually that works. Except in the camry, when I ground the system, I get MORE noise and TONS of noise lines on the TVIEW monitor. I have also thrown this same system in my 91 full size blazer, no issues with that.
If I just break down and get a DC-DC PSU would that solve the noise issue?
Is the electrical system in the camry so different then the blazer where I would need a ground loop isolator?
does anyone have any ideas?
TyBong is offline   Reply With Quote
Advertisement Sponsored links
Old 09-18-2005, 11:28 PM   #2
I think if you buy a dc-dc psu it will benefit you. It may or may not make the ground loop go away
EpRiDaZ is offline   Reply With Quote
Old 09-19-2005, 08:18 AM   #3
Switch-mode Inverters generate a hell of a lot of switching noise, which could be one of the problems.
Grounding the audio negatives from the PC is not a good idea. They use what's called a "floating earth", which is not necessarily 0 volts.
The best way to do it would be to use an isolation transformer/line isolator. You can get them many places, and work really well.
Additionally, use a noise filter/suppressor inline with the power input to both the PC and the monitor. That should cure the problems.
Jason_K is offline   Reply With Quote
Old 09-19-2005, 09:06 AM   #4
neon_eddy's Avatar
are you the guy from minnesota?..
I would agree, an inverter will most always make things more sucky, and indroduce that 60hz buzz.
I made my own ground lift, or "audio isloator" from radio shack parts.. cost around $10 but it worked, and saved some money from using BestBuy's $40 solution. just get 2 audio isolators, as they are mono and use the common ground and I also got 2 audio connectors, male and female so it could be in-line. hope those help.
Shawn
I jsut got an e85 conversion kit for my Audi 1.8t, it's very cool, and saves me money! e85 conversion kit
Check out my web company Minneapolis Web Designer - Himmelberger Design
neon_eddy is offline   Reply With Quote
Old 09-19-2005, 11:12 AM   #5
TyBong's Avatar
Cool, I work at a tv station with nuthing better to do somtimes, I think I may give that a try today, thanks for the imput
oh yea, yes I am the guy from MN
mabie I will not be lazy and fill out myprofile..... nope still too lazy Lol
Old 09-19-2005, 11:27 AM   #6
neon_eddy's Avatar
ahh what do you do there? I do some TV production work.. animation and whatnot.
you can try mine if you'd like.. as we live fairly close.
Shawn
Old 09-19-2005, 04:51 PM   #7
TyBong's Avatar
Cool, I do pretty much everything here, from production to managing playback, I suppose my main title would have to be a tech. i.e. right now sitting in the server room full of fans blairing in my ear Lol
Old 09-19-2005, 05:47 PM   #8
Please someone, correct me if I'm wrong, but I've read that inverters also create ~20% overhead in power draw. Just another reason to switch to DC-DC. Also, are all your components sharing a common ground or are they simply connected their nearest ground points?
bdrezner is offline   Reply With Quote
Old 09-19-2005, 11:03 PM   #9
PURDooM's Avatar
He works in champlin for clarification.
Current projects: iGmod reloaded (Latest release) (put on hiatus indefinatly)
Unlimited Internet and gps tracking for $6 a month with boost mobile!
Carputer 2: www.lmaocar.com
PURDooM is offline   Reply With Quote
Old 09-20-2005, 11:12 AM   #10
TyBong's Avatar
One more question, what would explain the same system in the blazer not having issues?
Old 09-20-2005, 03:13 PM   #11
neon_eddy's Avatar
well I would say, one of 2 things
1) better, newer alternator that intriduces little noise
2) better grounding in the veichle
better ground overall cna fix these issues .. the ground lift is more of a band-aid solution..
Shawn
can a carputer replace a high end av dedicated system? turbocad6 Car Audio 85 07-09-2007 05:44 AM
Noise on audio from laptop pip Laptops, Tablets, UPMCs, etc. 6 11-24-2006 08:09 PM
Inverter Question phatchink Power Supplies 27 08-21-2006 01:45 PM
Noise (from engine and other sources) HELP!!! sstylos Car Audio 6 09-20-2005 01:41 PM
odds of having ground noise? CornFlake340 Newbie 14 02-15-2005 05:01 AM
