09-23-2005, 12:32 PM
#16
Laptop, Tablets, UMPC Moderator
you really should check your tires more than twice a year..... the normal sepage that a tire incurs will outweigh the benifit of nitro....
09-23-2005, 12:36 PM
#17
MySQL Error
at the end of the day racing tyres are more critical and see greater temp changes. I doubt putting air in my tyres will cause me any real problems.
Nitrogen bottles are easy to come by though and wont have any moisture in so there is another benefit.
If you want more answers on anything I have posted you can find me at digital-car.co.uk
or skiing or diving or doing somthing else fun!
09-23-2005, 12:43 PM
#18
I guess nitro is a high performance alternative; they use it on plane wheels. The stresses on them are extreme, just re-run last night's news through.
09-23-2005, 01:13 PM
#19
unless your going 150 & drifting the apexes the tires won't vary much from parked to hwy.... that's really what it's all about......
09-23-2005, 01:24 PM
#20
MySQL Error
aircraft have to use dried gas due to the freezing temps so nitrogen is freely available with no water inside. Also if you have a fire in the gear bay or your brakes go on fire and cause the pressure release plug to melt then nitrogen getting released into flames is a bit safer than air!
09-23-2005, 01:36 PM
#21
MySQL Error
oh, further to earlier answers, i didnt realise that nitrogen and oxygen were so close together (been a few years since i looked at a periodic table). The difference in air to pure nitrogen relates to something like a 2.5% difference with temp. at car pressures that is not much but at aircraft and pressures (aircraft will crack regular tarmac due to the pressures) and race car tollerances i guess it counts.
At the end of the day....it's another one of those things to add social HP to your car down the local boozer!
09-23-2005, 01:54 PM
#22
yes.... pure bull sh%t in a passenger car.....
09-23-2005, 02:06 PM
#23
I'm sorry, and you are....?
The point of putting nitrogen only in the tires really has nothing to do with it being nitrogen, its the moisture content that really only makes a difference.
[H]4 Life
I'm a lesbian too.
I am for hire!
09-23-2005, 02:11 PM
#24
in other words it's a realatively cheap solution to a zero moisture content gas.
09-23-2005, 02:36 PM
#25
that I'd by...... if you use a clean shop w a clean air system it will be good though...., I guess nitrogen is a good way to garentee clean air though.....
09-23-2005, 02:45 PM
#26
I just don't know if it's actually worth the 5 bucks per tire. However I wasn't thinking about moisture and that might make a different for a car that sits all winter (i.e. an antique car)
Progress [I will seriously never be done!]
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
1GB Extreme III CF card
Carnetix 1260 startup/ DC-DC regulator
Software: Still, re-Writing my existing front end in .Net
09-23-2005, 03:14 PM
#27
so there charging you an extra 20 bucks so you can get what any good shop should be able to provide for free (clean filtered air)
09-24-2005, 01:07 AM
#28
I hear the nitrogen molecules are more complex and are bigger than O2. So you shouldn't lose tire pressure like the normal air filled tire.
09-24-2005, 11:18 AM
#29
Nitrogen is Diatomic, its much like Oxygen, its not going to be much differnt other than the fact its accually lighter than Oxygen is. Like previous posts have suggested, its only real benifit is for reducing moisture.
Jeep Grand Cherokee Laredo
Kenwood X790 x/ iP500 Ipod Interface
Elemental Designs 13Kv.2 D2
CDT ES-620 (omg yayay!!!1)
NINe.2X, NINe.2
09-24-2005, 01:32 PM
#30
MySQL Error
Well i am gonna fill my tyres wit helium to reduce unsprung weight
(but i suspect the helium will escape over time  )
| Thread Tools |
| Display Modes |
Linear Mode
