Go Back   MP3Car.com > Mp3Car Technical > General MP3Car Discussion
Old 11-17-2005, 11:36 PM   #1
Wrx Bolt In Kit
Does anyone know when mp3car will be getting more of the wrx bolt in kits in? I called them and they don't seem to know. Also maybe another place I can order it?
EpRiDaZ is offline   Reply With Quote
Old 11-17-2005, 11:46 PM   #2
fantomas's Avatar
www.digitalww.com seems to have them in stock...
rebuilding carpc... kinda..
fantomas is offline   Reply With Quote
Old 11-18-2005, 12:00 AM   #3
Sent you a PM
RR BuGGz is offline   Reply With Quote
Old 11-18-2005, 12:07 AM   #4
Thanks guys now with the liliput do I have to actually remove that screen from its original case to fit that bezel or does it just screw right into that bezel to fit into my sti?
Edit nevermind found the directions for installation.
Old 11-18-2005, 12:10 AM   #5
You have the remove the LCD from the original casing. Nothing too difficult just make sure all the ribbon cables are securely connected. Should take 5 min to take apart.
Dre
Old 11-18-2005, 12:11 AM   #6
I am probably going to order both the screen and bezel from digitalww.com has anyone ordered from them before? Are they a trust worthy company?
Old 11-18-2005, 12:12 AM   #7
2 STanGeR's Avatar
Yes.
2 STanGeR is offline   Reply With Quote
Old 11-18-2005, 12:16 AM   #8
Dre
Also once I do all this the bezel will just bolt right in with no modification into my 06 sti?
Old 11-28-2005, 08:50 PM   #9
Cyberphox's Avatar
Wouldn't these just fit into any car with a double din slot that had the room?
Cyberphox is offline   Reply With Quote
Old 11-28-2005, 10:31 PM   #10
Neither darque nor pervert
DarquePervert's Avatar
I would think so, but I don't know.
My plans are for a flip-out screen, but this has certainly piqued my curiosity several times.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 11-28-2005, 10:49 PM   #11
fantomas's Avatar
judging by the pictures, it would seem like you could put it anywhere. the wrx's stock radio has 3 screws on each side holding it in, but looking at the pictures, i don't see any mounting points for it which is odd becuase they would seem ideal.
i utilized these points for my custom case...
Old 11-28-2005, 11:09 PM   #12
It can fit in various cars with double din openings. On some cars the double din opening may be slightly bigger and may require som ecustomizing to fill the gaps. There are no mounting tabs on the TMZ bezel b/c you need to take the brackets off the sides of the factory radio and transfer them to the TMZ bezel. This will allow you to mount the TMZ bezel cage like a stock WRX radio.
Dre
Old 11-28-2005, 11:34 PM   #13
2 STanGeR's Avatar
It is standard double-din size. If your car has a double-din dash opening, then it will fit as long as somebody makes a dash kit for your specific vehicle. I would think that every vehicle should have the kit to make it fit.
Subaru WRX bolt in kit with toushcreen kalley LCD/Display 23 06-06-2006 02:06 PM
Subaru WRX bolt in toushcreen kit. impr3zy0u Classified Archive 3 11-05-2005 04:34 PM
Can i use this Car Kit with my Carputer? tyRion PhoneControl 2 05-21-2005 04:31 PM
Can i use this Car Kit with my Carputer? tyRion Wireless Communications 1 05-13-2005 08:10 PM
2004 WRX STI, use Xenarc? DWW kit? How to mount? Anyone with a STI? quinxy LCD/Display 15 03-03-2004 12:53 PM
