02-26-2006, 03:12 PM
#61
02-26-2006, 03:17 PM
#62
Quote: Originally Posted by Magnezium
I would like to put in the 10.4 inch screen, but we'll see how far my money goes. Sounds is more important then the screen since I'm not going to be watching the screen while I'm driving.
Lilliput makes a 10.4" touchscreen just like their smaller ones. About the same price as well. $260 + $40 for shipping. So about $300. For me it's not so much a question of money, it's just a matter of "can I get it to fit?".
Here's the link:
http://cgi.ebay.com/ebaymotors/Lilli...7772QQtcZphoto
http://stores.ebay.com/Extreme-Audio-Electronics-Ltd
03-11-2006, 04:21 AM
#63
My CarPC is coming along and for now Im using a tape adaptor for sound. I want to switch to something better and more permanent. Im not an audiophile so I dont need anything fancy. Can I plug into the monsoon amp? I know its near the spare tire but I havent looked at it yet. Could I run a lineout from my computer to the amp? Is the amp input RCA? Or should I do something different like aux-in?
Windows XP is ****!!!
AMD Sempron 3000+, ASRockVM800, 256MB, 250GB 3.5", DVDRW+, WIFIg, m2-atx, Lilliput 8", RR, GoogleEarth
Need: daylight viewable screen!
03-12-2006, 01:00 PM
#64
If you want to use the monsoon I would recommend going over to LS1tech.com and check the Stereo & Electronics section. There are sticky's about the monsoon. It is a very unique amp, not at all like an aftermarket unit. The tweeters on a monsoon system are powered from the headunit, some of the speakers are 2 ohm and there are no RCA in's.
Check over there, I'm sure there are threads on adapting it.
http://www.ls1tech.com/forums/forumdisplay.php?f=19
03-26-2006, 10:04 PM
#65
Has anybody mounted a screen in a thrdgen camaro? I got my carputer installed, and the last step is mounting the screen. I want it to look good. Any ideas?
03-27-2006, 07:18 AM
#66
What year is it and what kind of room in the dash do you have? I'll try and pull up some pictures and take a look. Do you have a common dash for your year or is it a unique model of car?
Are you going to remove the radio or do you need to add a screen and still have room for a radio?
I found some pics of a 86. How about using the location below the A/C vents and above the climate controls. I think you could fit a 7" in there and then just fill in the sides. Take a look at the pic below.
03-27-2006, 07:52 AM
#67
Hey guys, new car added to post #9. A 2002 camaro install from Z28CTYHNTR. Looks very professional.
03-27-2006, 09:49 AM
#68
Thanks jason. You called it, I have a unique model. It's a berlinetta. This is what I have to work with (not my car, but very similar) Thanks
http://www.thirdgen.org/techboard/at...7&d=1044557627
03-27-2006, 10:20 AM
#69
I think your really lucky. You have the perfect spot for a 10.4" LCD. Plus you have a sunshade with the dash. If you have room and no time, you may not even need to mold it in. Just mount the LCD with it's housing right there. If you want to get fancy you could make a new frame that better molds it in.
If I had your model of car I would stick the biggest screen I could right there in that cubby hole. You have room to change the angle on it plus it's within easy reach. Lucky bastard!
03-27-2006, 11:31 AM
#70
thanks for the reply man. My car is so close to completion. I hollowwed out the rear seat to hold the carputer. I'll get some pictures soon. It is wired into the sound system (kenwood 600 watt amp powering pioneer 3 way speakers ) and also the ECM to monitor aldl data. FUN FUN.
How's this screen? http://cgi.ebay.com/8-VGA-TFT-LCD-To...QQcmdZViewItem
03-27-2006, 11:38 AM
#71
Is the PC in the rear cushion kind of like my amps or do you mean in a bottom rear cushion?
I can't say on that LCD. You might want to check the forum and do a search on it. I wouldn't get anything less than a Liliput on the cheap end and maybe a Xenarc on the more expensive end. That one you showed is pretty cheap, so I'm wondering if the specs are correct. You never know, the display may not be as bright as they said it was. I trust the Liliput specs.
Did you measure your dash opening to see how big of a screen you could get in there?
03-27-2006, 11:43 AM
#72
sort of like your amps. The plexi glass case I made is horribly ugly though... the plexi I used was ancient and too brittle to make a nice case. Good thing you dont see it lol.
I'll go do a search on the forum. It is certainly cheap... I don't need anything extravegant. I'm looking for "adequate"
Thanks for all your help.
-Brendan
1985 Camaro Berlinetta, black with t-tops
500 MHZ dell CP Series
MP3 and ALDL data monitoring/wireless internet
kenwood 600 watt amp, powering pioneer 3 way speakers
03-29-2006, 06:37 PM
#73
Here are some pics of my install so far. Still have lots of work todo.
Need to hack up my lilli and radio bezel but im using this setup for now:
You cant see the screen here because of the camera flash but its a pretty acurate representation of how bad the reflection is when I am out driving during the day. It sucks!
Here is my USB port and ON/AUTO/OFF switch for my m2-atx
03-29-2006, 06:44 PM
#74
One more thing...here is what I used for a temporary mount for my lilli. It worked pretty well.
Just get a bolt the same size as the lilli mount bolt but much longer. Take off your radio bezel and mount the bolt as shown securing it with one nut. Put a 2nd nut on it and the square lilli nut on the very end. Slide your lilliput down on the square nut and loosen the 2nd nut on the bolt....this will put pressure on the lilli mount and hold your screen in place.
04-17-2006, 09:59 AM
#75
Nice thread Jason. I have a 2002 Pontiac Trans Am. I am just fed up with my clarion deck. I have been comtemplating this for a while. I guess i'm goin to try an tackle this in a couple of months. I will post as it goes. I have one question though. I prolly know its already been discussed but I searched an couldnt find it. Is there any way or has anyone come up with a way of losing the stock a/c controls an possibly having the controlled by the car puter. I mean most of it is electrical, except for I believe a vacuum line and another line (not sure what it is lol) sorry im more of a mechanical guy than a electrical. Anyways I was just wondering if it could be done. That way u still have the clean look. Also with the space of your glove compartment and center console or where ever u might stick it. Also on a side not that last camaro added on the first page is clean looking. Very clean and nice install I wish our dashes were that tall that way we could keep it stock looking as well.
| Thread Tools |
| Display Modes |
Linear Mode
