Go Back   MP3Car.com > Mp3Car Technical > General MP3Car Discussion
Old 11-26-2005, 11:09 PM   #1
ramy_zohair's Avatar
Ampie Car Case & PCI
Will i be able to fit a PCI card (using a card riser of course) on the Ampie case??? It looks like I wont be able to. I will be having a M10K MB.
ramy_zohair is offline   Reply With Quote
Old 11-26-2005, 11:15 PM   #2
Para Laura
thanatos106's Avatar
I don't think is possible.
What pci card? what for?
Thanatos.
RexBruMet Skin for FrodoPlayer
Nissan Aux-in MOD
Quote: Originally Posted by bgoodman
We're an international forum, post in whatever langauge you like.
thanatos106 is offline   Reply With Quote
Old 11-26-2005, 11:47 PM   #3
maybe an TV/FM card or a usb to PCI one. not sure yet. Just to make sure i'm planning right.
What about the RAM, does it have to be the ultra low profile??? or can i use the normal ones. Ultra low will cost me $150 for 512, the others will cost only $50.
How many 2.5" HD can i fit? I searched by I'm getting mixed replies, some say 1 & others say 2. besides, i see that some people have problem fitting the 2.5 IDE drive adaptor in the case. will the one that mp3car sells, fit with no problems??
Old 11-26-2005, 11:56 PM   #4
Para Laura
Quote: Originally Posted by Zip-Lock
It's a nice case. Here are my first impressions:
Pluses:
  • will accept any size RAM, no "low-profile" requirements
  • nice wiring harnesses to connect to the M1-ATX and then a harness to connect to your vehicle
  • nice mounting brackets.
  • Small size
  • Looks better then any other case
Negatives:
  • single fan in the back has a short power wire, not able to reach to connect to the MII12000 board I was using
  • Blue paint color mismatch between case and metal bracket
  • Screwing in those black screws into the aluminum case can be hard, it takes effort to keep the screws going in straight.
  • No room for PCI slots
  • No room for slot load optical drive
  • Pretty much have to use M1-ATX power supply so that means no motherboards with a P4 connector.
http://www.mp3car.com/vbulletin/general-hardware-discussion/52755-ampie-case-information-pictures.html
-Regular ddr size.
-Two 2.5" HD
-Yes there have been reports from people about the IDE adapter (but they MOD it to make it work)
THanatos.
Nissan Aux-in MOD
Old 11-27-2005, 12:28 AM   #5
thnx man
Old 11-27-2005, 12:45 AM   #6
Raw Wave
EsKALad's Avatar
yes ramy. i recently built this case with the mii12000 and i had a slight problem with the 2.5 hd adapter i had. your best bet is to use the one like digitalww.com has. anything too big or in the way will cause the case not to close due to the fan. i highly doubt a pci card will go in. just get usb tv tuner with fm. yes regular memory will fit fine. 50 bucks for 512mb is what i payed. im not so sure where the 2nd hdd will go. but why dont you just get a nice 100 gig lappy drive from pricewatch and stick that in there. way more than enough storage.
i got dat ***** sittin on 22s! SUPERMAN EDITION!
EsKALad is offline   Reply With Quote
Old 11-27-2005, 12:46 AM   #7
Para Laura
No problem.
Thanatos.
Nissan Aux-in MOD
Old 11-27-2005, 09:28 AM   #8
MySQL Error
Sonicxtacy02's Avatar
i have an opposite facing riser card that might work for you in the ampie case. It worked with my via 800 in an amp case i gutted. PM me if youre interested. Basically it puts the pci device over the motherboard instead of away from the motherboard.
Old 11-27-2005, 06:08 PM   #9
fonseca's Avatar
Does that one use an 80 conductor ribbon?
I bought one like it but it was the speed-limiting 40 wire version.
In progress: M10000; Travla c134; Xenarc 700TSV; Hitachi 80GB 2.5"; 256MB ULP; M2-ATX; ITPS; Powermate; iKEY SL-88 KB; Holux GM-210; Audiobahn ADD51T w/ COAX/optical converter; Road Runner; iGuidance 2.1
fonseca is offline   Reply With Quote
Old 01-12-2006, 08:47 PM   #10
great i have the same case but only problem is i have the DSATX PSU and was wondering where am i going to put it? anyone tried anything in a simillar situation. I was thinking of drilling the case on the top to mount it their should i run into any problems? or does anybody have any other Ideas?
arawas is offline   Reply With Quote
FAQ: How do climate extremes affect a Car PC? Bugbyte The FAQ Emporium 34 05-16-2007 07:34 PM
First Car PC Questions - Pretty Long Post Sorry :D [56k death] FiReToY Newbie 9 06-08-2006 06:15 PM
Painting Ampie Case semovodka General MP3Car Discussion 2 10-08-2005 05:37 PM
DC-DC car power supply for ITX case mrandery Power Supplies 30 08-30-2002 09:30 AM
some pictures of my car and custom case Awol][ General MP3Car Discussion 9 12-07-2000 09:04 AM
