Go Back   MP3Car.com > Mp3Car Technical > General MP3Car Discussion
Old 12-10-2005, 12:16 PM   #1
Solar Battery Charger
Ive been thinking alot about my battery dieing due to power draw from my opus power supply. My current battery is a 70ah but I offten leave the car and not run it for atleast 2 days or so. I have a moon roof on my car that I almost never remove the sun gaurd unless i have it open. So I was thinking about buying a 15watt or so 12volt solar pannel and a charge controler to maintain and charge up my battery. http://www.batterystuff.com/productd...?id=620&c=9&f=
I would mold it ontop of my moonroof and cover and seal it with plexy. It would raise it about 1/4 of an inch and wouldnt look outa place. Any thoughts or would it work as well being mounted on my rear deck under neath my rear window.
Jcarere is offline   Reply With Quote
Old 12-10-2005, 12:54 PM   #2
anyone have experience with solar battery charger or comments / suggestions????
Old 12-10-2005, 01:11 PM   #3
kirbycope's Avatar
You can do it yourself for sub $100. and use the
http://www.mp3car.com/vbulletin/power-supplies/53640-solar-panel-battery-charger.html
Post Whore's tip:
User CP-> Edit Options-> Number of Posts to Show Per Page-> 100
http://www.frappr.com/mp3car from this thread http://www.mp3car.com/vbulletin/general-mp3car-discussion/65044-frappr.html
kirbycope is offline   Reply With Quote
Old 12-10-2005, 02:01 PM   #4
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
This comes up about every 6 months.
1. Solar panels don't generate enough power to run your computer unless you cover your car with them.
2. You don't need a solar panel when the car is on
3. Solar panels are wicked expensive. Instead, install a tank circuit (search terms: "tank circuit" or check the FAQ Emporium
4. If you computer is either hibernating or off, it won't kill your battery. If it is sleeping, perhaps....JUST PERHAPS a solar panel is an option, but since the Opus has a low voltage cutoff, it won't run your battery dead if it is working properly. See also: tank circuits
Solar: An expensive and impractical solution to a problem you can solve more cheaply and reliably using other methods.
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Old 12-10-2005, 04:02 PM   #5
Unregistered User
ODYSSEY's Avatar
Looked into this years ago. Price vs amps sucks.
ODYSSEY
Quote: Originally Posted by Tidder View Post
Digital-Car UK|
(\__/)
(")_(")
ODYSSEY is offline   Reply With Quote
Old 12-10-2005, 06:48 PM   #6
MySQL Error
MatrixPC's Avatar
Actually you guys miss the point of his post.
Well, the Opus is draining the battery so he's trying to use solar panel to keep the battery charge.
I think you can use it if the solar panel can supply more juice than the draining by the PSU.
Well, to really solve the problem, you have to fix the draining.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is online now   Reply With Quote
Old 12-10-2005, 06:51 PM   #7
arebelspy's Avatar
Quote: Originally Posted by kirbycope
You totally confused me kirby, I thought there was a new search picture.
-arebelspy
See my trades here! My For Sale/Trade Thread. Email joe at eipse.com
Quote: Originally Posted by xdjxklusivex
i think every thread is now a whoreing thread
arebelspy is offline   Reply With Quote
Old 12-10-2005, 10:03 PM   #8
kirbycope's Avatar
i am slick like that:
http://pages.infinit.net/bluefire/
Old 12-11-2005, 12:02 AM   #9
Bugbyte's Avatar
I didn't miss the point. It's cheaper to use a tank circuit. Who knows if the sun will be shining when he needs it to be? A tank circuit is both cheaper and the Opus can cut off the computer when the volts get too low.
Worst case scenario is when he starts the car, the computer reboots.
Now, if you want solar because it's cool, well then, okay. But it ranks pretty low on the practicality/cost scale.
Old 12-11-2005, 12:04 AM   #10
binary.h4x's Avatar
that little flashing led on the Opus isn't gonna kill your car in a couple of days.
binary.h4x is offline   Reply With Quote
Do I Need To Beef Up My Alternator Or Anything Else chitown_16 Car Audio 23 06-19-2006 07:39 AM
Solar panel battery charger kirbycope Power Supplies 3 06-29-2005 10:13 PM
MPJA - MECI ASTEC DC-DC Converter Luc General Hardware Discussion 39 11-22-2004 10:31 PM
Car power supply (battery charger) from old pc supply stimps Power Supplies 8 08-24-2004 08:59 AM
Using Battery Charger in the House? dug1967 General Hardware Discussion 3 05-14-2004 11:55 AM
