Go Back   MP3Car.com > Mp3Car Technical > General MP3Car Discussion
Old 12-11-2005, 07:31 PM   #1
whosyourdady08 is on a distinguished road
Can I use a Remote Turn On from Head UNit to power Motherboard?
can i use a remote turn on with a relay from my head unit to power a computer given it is 12v+ (so it will turn on at the same time as radio) or should i simply just get the opus 150w
whosyourdady08 is offline   Reply With Quote
Old 12-11-2005, 07:44 PM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
Get the Opus 150w.
For one, the 12v isn't regulated. The unregulated power can and will fry your motherboard.
For two, the motherboard requires more than just 12v to operate. the motherboard is fed 12v, 5v and 3.3v from the PSU to operate properly.
For three, it's likely that the remote turn-on wire is only a pulse that's used by other devices (an amplifier for example) to initiate turn-on.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 12-11-2005, 07:53 PM   #3
My man uses Levitra.
Peoples's Avatar
Peoples is on a distinguished road
dont double post.....you son of a *****
PC Components:
My work log
Peoples is offline   Reply With Quote
Old 12-11-2005, 08:46 PM   #4
While the double-post is frowned upon, I'd not be so hasty to accuse.
I've seen the forums having some issues that have resulted in a double-post from me as a result.
Old 12-11-2005, 08:48 PM   #5
Jahntassa's Avatar
Jahntassa is on a distinguished road
Remote turn-on from the headunit (either ACC or the actual Remote turn-on lead from an aftermarket radio) is constant 12+v while the unit is active.
Jahntassa is offline   Reply With Quote
Old 12-11-2005, 09:06 PM   #6
Jcarere is on a distinguished road
But it also has a very low limit on current. Most headunits can only facilitate a 200 - 500 ma draw so becareful on your choice of relay.
Jcarere is offline   Reply With Quote
Old 12-11-2005, 09:18 PM   #7
I've decided just to get the Opus 150w and use the remote as the igg turn on..Thanks for your help though.
Modding the new Motorized VGA Screens Wiredwrx LCD/Display 147 06-04-2007 04:53 PM
Can a car-computer replace a stereo head unit? CA 3000GT General Hardware Discussion 22 11-13-2006 10:24 PM
New Sony head unit - botched wiring... SamDude Car Audio 4 09-09-2004 05:21 PM
remote turn on lead from headunit to power up PC BluCivic93 General Hardware Discussion 3 07-27-2000 03:13 PM
car head unit BoneMan General Hardware Discussion 1 07-29-1999 10:30 PM
