12-14-2005, 11:14 PM
#1
So has anyone actually come up with a hard drive heating solution?
I've read a bunch of posts with people shooting out ideas, but haven't seen anyone actually implement anything.
BB HDDs don't seem to be completely immune to these problems, I don't want to boot from CF, and it's cold in Canada...
Some ideas that people have had:
Watlow Flexible Heaters... these are really cool.
http://www.watlow.com/products/heaters/ht_flex.cfm
http://www.watlow.com/products/heaters/ht_syringe.cfm
Looks like they have temperature sensors.
Another idea:
Use a Stamp module ( http://www.parallax.com/html_pages/p...sic_stamps.asp) and their digital thermometer ( http://www.parallax.com/detail.asp?product_id=604-00002).
I've never programmed these before, but it's probably ridiculously simple to program these things. When you deal with the temperature measurement, sure you could easily tell what the ambient temp around the drive is.
If you provide a low amount of constant heat, you might be able to keep this heat applied, safely, until the ambient temperature naturally rises (I would imagine that the heat given off by the heater would be minimal, although I am not sure). Unless you could actually measure the temperature of the drive itself, and not the air around it? This way you can probe the drive for a temp. reading, and not care about the air around it.
You would also need to have some sort of heating element. The Watlow would work well here, I would imagine (providing it does not have its own sensor circuitry).
Does anyone know of any other heating elements that would work well? Or how to accurately measure the temperature of the drive? Or if this would work with only one side of the drive having direct heat applied to it? Or if this is a good idea?
Obviously lower power consumption is better, although I am quite sure that I am adding a 2nd battery, so current usage is not extremely critical.
I've actually sent a "Heater Application Request" to Watlow. I wonder if they'll get back.
'03 Intensa Blue Pearl Lexus IS300
Specs: Xenarc 700TS, Opus 150W PSU, CarCPU Case, 2.0 GHz Celeron D, DFI PS-35-BL, SB Audigy2 NX, Centrafuse 1.4
Progress: Car PC up and running!
To Do: Navigation, WiFi, AM/FM Radio, DVD
12-14-2005, 11:32 PM
#2
Peltier (has side benefit of being reversible during summer months for cooling)
Heating element for Nitrous bottle?
Take a look at iButtons (ibutton.com) and affix the temp sensor ones to the hard drive, run interface with it using serial cable and you got temp monitoring.
2004 Eclipse GTS v6 Turbo, NOS
Plantronic in-dash LCD
Via Epia M2 1200 with WiFi and CF Microdrives
OBD2
Rino 120 GPS
12-14-2005, 11:56 PM
#3
Peltier has me feeling a little weary. I'd rather not go that route unless completely necessary.
So are you suggesting iButtons with the N20 heating element? Do you have any more info on these heaters?
I'm still not sure about the actual "hard drive heating part". I mean, you're just heating the surface.
If I put the sensor and the heating element on the same side, then naturally the sensor is going to be a lot warmer than the temp on the other.
If I put the sensor on the opposite side of the heating element, then the side with the heating element is going to get a lot hotter than the side with the sensor, before the sensor reaches its cutoff temp.
Or I could try two sensors and two heaters.
I think one key issue is determining how hot these hard drives actually are, not on the surface. They are made up of several materials...
12-15-2005, 06:31 AM
#4
Neither darque nor pervert
Move to a warmer climate?
Sorry. I know this was a blatant post-whoring, but I really felt I had to.
Here's my take on the situation:
Hard drive casings are made of aluminum, which is very good at transferring heat (or cold). The idea of heating up the external case of the HDD to the point where it will make the fluid bearings viscous enough for the HDD to spin up is a sound idea.
If you're going to go with a heating element that heats up a small surface area (such as a peltier), you'd want to focus that heat on the area near the spindle, as that's where the bearings are. Another point to consider is the axle for the arms that have the read/write heads attached (I'm sure there's a name for this, but I don't know it).
My Worklog
12-15-2005, 07:40 AM
#5
What about the power draw of the peltier?
1995 Ford Mustang Convertible
DSATX | Shuttle XPC SN41G2Bv2 | 619GL-70NP | CF 1.6 (which is still unusable in the car!)
12-15-2005, 12:56 PM
#6
A quick, dirty, and cheap way that came to my mind first was to use a small incandescent light bulb. Paint it black and affix it close to the point/s needing warmth. It depends on just how much heat you need. Not very elegant and probably not as efficient as a dedicated heater due to some of the energy going to light output.
Don't hard drives use 20 watts or so on their own? If it was wired to its own separate power supply that never turned off keeping the platter/s spinning continuously, it would (hopefully) keep itself heated. Add some insulation if needed to blanket the drive if it doesn't stay warm enough. Tailor things as seasons change, etc.
12-15-2005, 02:28 PM
#7
you can kill your battery, you will wear down and kill motors in your drives faster, you can start a fire by heating up the blankets enough.
OBD2
Rino 120 GPS
12-15-2005, 02:45 PM
#8
this is just an idea, but what about mounting the HDD or possibly the whole computer near one of the HVAC vents in the vehicle? you'd have to wait a few minutes to let heater warm up, but you could also use the vent to cool the drive in the summer... not that you would need to living in canada though...
12-15-2005, 02:50 PM
#9
If you ran a dryer hose from the vent to a specially crafted box that concentrates hot/cold air and lets it out at a rate slower then it allows in, you may have somethign workable. My borther did somethign similar on his desktop machine and ran a dryer hose from the vent to the 120mm fan intake.
Lets see what others think.
OBD2
Rino 120 GPS
12-15-2005, 03:20 PM
#11
This might be an idea about cooling but I am not sure if it would work well. I know amp racks run auxillary 12 volt fans. I am sure it could be on a wired sensor to turn the fan on at certain temps and off at others. I suppose this depends on how much room you have too. I think parts express may have these as well as other sites.
12-15-2005, 03:40 PM
#12
Save yourself the trouble and buy a temp controlled fan with a built in tepm sensor.
OBD2
Rino 120 GPS
12-15-2005, 03:52 PM
#13
Calm Down Or Get A 2 Week Vacation -Love The Forum Policeman
This might be a good place to start
http://www.heatal.com/
Damn, not I am thinking I should have said
http://www.sportsimportsltd.com/12voltheaters.html
http://www.sciplus.com/singleItem.cf...TOKEN=66849742
Then it is a matter of powering it, and turning it on and off.
I sent them an e-mail asking for some tech sheets and specs, lets see what they say. It looks like they are mostly used as reptile heaters.
Michael
...I love the French language...especially to curse with...Nom de Dieu de putain de bordel de merde de saloperies de connards d'enculés de ta mère. You see, it's like wiping your *** with silk, I love it. www.yellinlawoffice.com
12-15-2005, 04:01 PM
#14
That won't HEAT the HD, though, it might be useable in conjunction with some of the heating elements I linked to.
Michael
12-15-2005, 04:06 PM
#15
good luck in getting email responses. I very seldom get replies on emails but if it is about a product, no reply no sale is my motto.
| Thread Tools |
| Display Modes |
Linear Mode
