Quote: Originally Posted by z32_vg30dett_z3
first of all, when i turn to ignition key to start the engine my cpu shuts down. i thought the power supply is supposed to take care of that.
Sounds like you have the M1 power wire hooked up to a source that is not 12volts when the key is in the start position. It needs to be hooked up to 12volt constant/allways 12volts
secondly i hear hissing from the computer through the cars speakers. (some power wire near audio wire?)
Check your grounds, and search the forums related to this. Certainly a ground problem though.
