Go Back   MP3Car.com > Mp3Car Technical > General MP3Car Discussion
Old 01-27-2007, 05:17 PM   #16
One Sharp Cheddar
ThunderStick's Avatar
ThunderStick is on a distinguished road
How about using an opus power supply with this but instead of using the atx power connection just use the 12v connection from the PSU.
Just a thought. WIll this work.
IF not, sorry I just thought I would run it by. Not sure if the opus needs to run with the ATX power connector.
ThunderStick is offline   Reply With Quote
Old 02-13-2007, 10:15 PM   #17
BAHitman is on a distinguished road
I suppose as long as the regulator can handle the current draw on the 12v power plane of that PSU, it would definately not hurt anything... but you have to check the amperage of the 12v power plane of that PSU.
My system is still running fine after over 1 year of operation straight from the battery...
BAHitman is offline   Reply With Quote
Old 04-02-2007, 10:23 PM   #18
walstib's Avatar
walstib is on a distinguished road
BAHitman,
I'm thinking of replacing my VIA Nano 10000 with an SX260. You have no startup/shutdown controller? Just straight to ACC power? So you have to perform a shutdown or hibernate every time you turn off the car? I know I would never remember...
Carputer Project Status:
0% - Mobo died on 2/17/08
Check out the worklog for my '01 Pathfinder.
walstib is offline   Reply With Quote
Old 04-02-2007, 11:05 PM   #19
One Sharp Cheddar
Quote: Originally Posted by walstib View Post
BAHitman,
Check out this thread, I give a full explenation on how to setup up your sx260 or sx270 with a carnetix p2140 that has a built in shutdown controller.
http://www.mp3car.com/vbulletin/powe...-question.html
Old 04-02-2007, 11:10 PM   #20
walstib's Avatar
@ThunderStick
Awesome! I saw another thread where you had used a switch and relay. Thank you!
Old 04-03-2007, 06:33 PM   #21
One Sharp Cheddar
No need for a relay, infact the relay would work against the PSU. Do not use the relay as shown in that scheme. A switch can be added on wire from your switched 12v or your accessory line. This will allow you to shutdown your PC when not in use. This is what I am doing as we speak.
Yes I am starting my install
YIPPEE
dell sx260 dc power supply? driv3nneon Power Supplies 1 04-25-2006 01:01 PM
dell optiplex sx260 tower... joshoowa Newbie 3 04-25-2006 12:56 PM
Need Advice for a Dell SX270 setup xs10x Power Supplies 5 12-09-2005 12:36 PM
Buying new monitor for home computer. ppgt94 Off Topic 13 08-26-2005 09:42 PM
Why not use a 1U rackmount server as carputer? index General Hardware Discussion 8 08-26-2005 06:52 AM
